Baselworld 2016 Doxa Sub 6000T available for pre-order
OLYMPUS DIGITAL CAMERA
Arguably one of the most admired brands on Watchuseek, Doxa has just announced the release of the Doxa Sub 6000T Professional Baselworld 2016 release. It’s available for pre-order now at $1990.00 as opposed to the regular web store price of $2490.00. The watch will be shipped at the end of April.
The new watch comes with a higher depth rating (6000ft vs. 5000ft), better lume, and the watch runs on a Soprod automatic A10 movement. There are also some minor changes to gasket positioning and quality.
The orange outer numbers on the bezel are designed to tell you the maximum amount of time you can be at the marked depth. So for example, in the event you reach a maximum depth of 150ft, your total time from leaving the surface to starting your ascent (bottom-time) would need to be less than 6 minutes. If you’re only going as deep as  70 feet your bottom time can be up to 70 minutes.
Specifications
Functions: Hours, Minutes, Seconds and Date
Case: Stainless Steel
Crystal: Sapphire Crystal
Case Back: Solid
Dial: Orange
Hand Indicators: Luminous
Hour Markers: Luminous
Water Resistant:  1800M
Movement:  Automatic
Bracelet: Stainless Steel
Order here
Comments
comments
