MB&F Legacy Machine N°1 Final Edition
Completing an MB&F series is a major strategic decision and is central to the belief in continual exploration and development that is held by everyone at MB&F. Only by ending production of existing pieces are Maximilian Büsser and his team able to move on to future challenges while keeping the creative spark and momentum that comes with a compact organisation.
The Legacy Machine N°1 Final Edition makes the last outing of the series in steel, with a dark chocolate face, wearing the white lacquer dials, suspended balance and gracefully arched power reserve indication in their well-known configuration. A new balance bridge, cambered and tapered in the style MB&F introduced to audiences in the Legacy Machine 101, is the one departure from the original design and acknowledges the evolution and maturation of the Legacy Machine collection.
lm1-final-edition_face_lres
The dark chocolate-toned face of the LM1 Final Edition is not the first instance of this color appearing in an MB&F creation. Wherever and whenever it occurs in the MB&F collections, the deep brown hue signals a special occasion, a reason to break out the treats, and the Legacy Machine N°1 Final Edition is no exception to this rule. The launch of the last LM1 may be a bittersweet celebration for some.  MB&F founder Maximilian Büsser pinpoints it at 85% dark chocolate since the edition is limited to 18 pieces.
EVOLUTIONARY BRIDGE
The balance bridge of the Legacy Machine N°1 Final Edition is new in the LM1 series. It follows the code premiered in the Legacy Machine 101, which has since been propagated in the LM2 series via its titanium incarnation, and in the Legacy Machine Perpetual.
The original LM1 came about as a reanimation of 19th-century design, particularly in association with technological advances. The open-worked balance bridge, with its sharply defined angles, echoed the girders and crossbeams of industrial structures showcased at the famous World’s Fairs of that era.
lm1-final-edition_lres
As the Legacy Machine collection grew into its own, its focus naturally shifted away from specific historical design references. A smoothly curved balance bridge with an elliptical cross section, milled from a single steel block and demonstrative of a high level of machining sophistication, was designed to fit the smaller proportions of the Legacy Machine 101.
lm1-final-edition_back_lres
Thereafter, it made its second appearance in the 2015 Legacy Machine Perpetual and again in the 2017 LM2 Titanium. The lithe, mirror polished arms of the redesigned balance bridge set it apart from the satin-finished bridge of the original LM1, seemingly a small detail, but one that magnifies the impact of the floating balance. The polished balance bridge clearly stands out against the sunray-finished base, cinematically emphasising the aerial poise and height of the balance.
LEGACY MACHINE N°1 SERIES – TECHNICAL SPECIFICATIONS
Legacy Machine No.1 is available in 18k red gold, 18k white gold, a limited edition of 33 pieces in platinum, a limited edition of 13 pieces for the M.A.D.Gallery Dubai in titanium and the final edition limited to 18 pieces in stainless steel. The LM1 was also the base for two Performance Art editions with artists Xia Hang and Alain Silberstein.
Engine
lm1-final-edition-engine_lres
Three-dimensional horological movement developed exclusively for MB&F by Chronode with bridge design and finishing specified by Kari Voutilainen
Manual winding with single mainspring barrel
Power reserve: 45 hours
Balance wheel: bespoke 14mm balance wheel with four traditional regulating screws floating above the movement and dials
Balance spring: traditional Breguet curve terminating in mobile stud holder
Balance frequency: 2.5 Hz / 18,000 bph
Number of components: 279
Number of jewels: 23
Superlative hand finishing throughout respecting 19th century style; polished internal bevel angles highlighting handcraft; polished bevels; Geneva waves; gold chatons with polished countersinks; hand-made engravings
Functions
Hours and minutes; completely independent dual time zones displayed on two dials; unique vertical power reserve
Left crown at 8 o’clock for setting time of left dial; right crown at 4 o’clock for setting time of right dial and winding
 Case
18k red gold or white gold, platinum 950, grade 5 titanium or stainless steel.
Dimensions: 44mm diameter x 16mm height
Number of components: 65
Sapphire crystals
High domed sapphire crystal on top and sapphire crystal on back with anti-reflective coating on both sides
Strap and buckle
Black or brown hand-stitched alligator strap with 18k gold, platinum, titanium or stainless steel buckle matching the case.
Visit MB&F
Comments
comments
