U-BOAT founder and designer Italo Fontana introduces a new version of his "Classico" design. Designed for both men and women with a strong personality and broad wrists, this new Classico is 47mm in diameter and will be available at a new and apparently appealing prize range, as yet unannounced.
As with the previous editions, it will feature a left-hand crown placement with the characteristic U-BOAT crown guard. Available with a black or beige color dial, the watch features a stainless steel 316L AISI case, satin hand-finish with a serial number engraved on a small plate fixed on the side of the case.
On the dial the 'U' in U-BOAT replaces the index and number at 12 o'clock. The watch features hours, minutes, seconds and date functions through the U-28 automatic mechanical, personalized to U-BOAT specifications. In addition to the hand-made and hand finished calf leather belt, an extra strap with Kodiak with water repellent treatment is included in the box.
Specifications
MOVEMENT: U-28 automatic mechanical, personalized to U-BOAT
specifications for stem to be positioned at 9 o'clock. Frequency: 28,800 vibrations per hour, 4 Hz. Power reserve: 38 hours. 25 jewels.
FUNCTIONS: Hours, minutes, seconds, date.
CASE: Stainless steel 316L AISI, satin hand finish, distinguishing crown on left side, with a patented protective device. Diameter 47 mm.
Serial number engraved on a small plate fixed on the side of the case.
BACK: Screwed in, fumè glass showing the skeleton balance wheel.
DIAL: Three superimposed layers, black with visible ruby. Arabic numerals, luminous hands, numbers and markers.
CRYSTAL: High quality sapphire, scratchproof.
WATER RESISTANCE: 100 meters
STRAP: Hand made and hand finished calf leather, tongue buckle in steel. Width 23/22 mm
Visit U-BOAT
Specifications
Visit U-BOAT
