1 - 3 of 3 Posts
Are there gaskets that will work with the 9700 that is not from a 9700? Sourcing one is near impossible. Anyone know if the case is the same as another G? I dont want to crack the back open without one.
Thanks.
Mike
There are probably other models that use the same gasket, but why not take a look inside? You might find that the gasket is perfectly fine. You can just put some silicone grease on it and you'd be good to go.
1 - 3 of 3 Posts
