Can someone explain the difference between low drain vs. high drain silver oxide batteries?
For example 380 vs 394. I've read specifications with the capacity being 84mAh for the 394 and 82mAh for the 380, but the 380 is advertised as high drain. Seems opposite.
Energizer actually packages the 394/380 as the same battery, while Renata sells them as two separate batteries. So is there any difference?
