1 - 3 of 3 Posts
Hi recently picked up a Aerospace read manual and i have a little experince with the functions etc as owned a new chronospace, problem in when setting the watch the hands dont match the digital display by around 7 mins, i have mostly experience with mechanical watches in that i can do most adjustments hand changes etc so im not afraid to go into the watch if i get enough info to do it, any help would be much appreciated so thanks in advance and merry chrimbo!:)
Try this - turn crown until bottom display is blank, then pull out crown. This will allow you to move hands independent of digital time. If you want them matching, this is how you do it. I keep my hands 5 minutes ahead of digital time for the hell of it. This is based on my emergency, I think it works the same. I use this function when traveling overseas to change time back and forth easily and quickly.
Hope it works for you.
1 - 3 of 3 Posts
