1 - 20 of 24 Posts
Hello guys
Does anyone know where I can get the speaker sticker on a case back?
I got a Screwback full case as a part but as you see no speaker
When I attach and hold the back plate from the 5600e and push the button it beeps
When I screw the case back it doesn't
Tried to remove the sticker but no luck
It brakes in small pieces
Even after heating with a hairdryer
i contact casio service at my country and they told me that this is not sold as a spare, it comes with the backplate, or caseback
Can anyone help ?
Thanks in advance !
G.
Re: Help with a built project. Need a speaker for Screwback
Unfortunately, no. :-(
Casio's "tape/adhesive" is just that -- two-sided tape cut at the factory to a specific shape, usually used to temporarily attach G-Shock pieces together during assembly. Casio often uses it to, say, hold an inner bezel in place to make installing an outer bezel easier, and to keep the inner bezel from falling on the floor if the outer one is removed when servicing the watch.
Thank you very much Mike for the reply
Will go tomorrow to a store near me
I might find
Hoping to update with good news
Overall I m very happy with the final result
All it s left it to be fully functional with an alarm
G.
Discussion Starter #8 (Edited)
Less than 0.5mm is ok I believe
If I will not find anything tomorrow I will order these
Thank you
This watch is made with parts
Dw5030c case set from pacparts
Dw5030c lcd from pacparts
Gw5000 Band & bezel ,
spring bars & bezel screws from pacparts
1545 module, from a beat up used dw 5600e with faded lcd from eBay
G.
Is there a certain current that the speaker needs to draw in order to work?
For these it is very low voltage. More important is that is an oscillating voltage or it won't make a sound but that is taken care of by the watch circuitry. The oscillating voltage causes the disc to flex thus making the sound.
Actually the ceramic disc that makes the sound will also make a spark if squeezed or hit, used to light lighters that don't use a flint.
So here is my obvious question then. If the module sends a current to the alarm spring, will the charge ignite the ceramic speaker causing it to spark?
No, it would need to be struck or squeezed to emit a spark of electricity. Oscillating voltage causes it to move and make a sound just like a regular speaker does.
I found this to explain it;
http://www.eng.utah.edu/~cs5789/handouts/piezo.pdf
Discussion Starter #13 (Edited)
The bad news is that I did not found what I was looking for in the store
The good news is that I remember I had somewhere an old FLUKE multimeter
Those devises that beep in some modes,and thought it must have something like this on it
So I took out the box with the things I do not use but is good to have around for spares
Open it up
And I could not believe my luck !!!
2cm piezo buzzer in
Gentlemen I have a fully functional Dw5030c from parts
also, for reference
i asked that ebay seller and the functional voltage is 1,5V up to 30V
i ll order some, now that i know that works !
G.
Discussion Starter #15
Re: Building a DW5030C from parts.Help with piezzo buzzer
I hope you manage to get the speaker, great looking mod.
Thank you !
It is working with the one I used from the multimeter
Waiting to receive the one I ordered from eBay
Some shots
Will update when I receive the piezo buzzer
G.
Discussion Starter #19
Depends of where you live and how you want to do it.
I got a used 5600 for the module
Also two friends helped me from US , and since the parts were in two different orders, I payed twice the postage plus twice the postage to get to me in Greece.
You can check from pacparts what you want and calculate the cost
It s very easy
If you do it give us an update
Merry Christmas to you all
G.
It s very easy
G.
Surely I will post some pictures Giorgos. I already placed my order at pacparts for the body parts (center casing, including buttons) and 4 bezel screws. Now, I am looking for an old DW-5600E. If I can't find an old DW-5600e until my order from Pacparts comes, I will buy a new DW-5600EG.
1 - 20 of 24 Posts
