1 - 7 of 7 Posts
I have a 1988 Casio AQW-5 that I fgound in my draw the other day, I have got it up and running with new battery but the hands and digital display are not the same. Any ideas how I can sync them?
Thank you
15558460
Moderator G-Shock Forum
that should be the right top recessed button.
If you press that button the movement will move forward and you can hand sync it with the digital time. :)
Thank you, it moved and now stopped so may be a problem with the button will have a look and see what I can do.
Rocket1991, thank you. I could not find one on Casio using either 308 code or AQW its probably too old like me :)
U sure it’s 308 not 380? Here’s 380 manual I found. It was meant for G-Shock AW-500 but layout seems same as yours.
You may also try this site for vintage model manuals. It also has a 308 manual but seems to be without digital window, so I’m not sure.
Update: check 303 or 305 manual, seems closer to yours.
I found that if you search for 308 it brings up other models that use that module, and they are ana/digi watches.
When you search for one of those model's manual, rather than a 308 manual, they do mention using the top right button to move the hands.
My old AW-500 has similar layout of ana-digi. And it used too right button to move analog minute hand, that’s the only way to sync analog to digital display, no automatic sync.
1 - 7 of 7 Posts
