Buzz, i hope u dun mind. ive been keeping a list from ur thread.
Casio Parts
800-223-2001
9:00am - 5:00pm eastern time
Monday - Friday
total flat shipping is $4.95
Gasket DW-5700 will fit DW-5000 reissues with a 1545 module
DW-5600-E face protector = #74299032
DW-5600-E end pieces/strap adapters = #74243710
DW-5700 = #10058072
DW-5600-C bezel = #72101103
DW-6900/DW-6600 case back gasket = #74210703
CTL1616 battery = #10065657
DW-5000/DW-5025 o-ring REISSUE (SCREWBACK COVER and SS case.)= #74209681
Dawn Black Frogman case back gasket = #10052478
Dawn Black Frogman bezel = #10271360 = $16.00
Dawn Black Frogman spring bar = #74292578
Dawn Black Frogman Resin Strap = #10271341 = $19.50
Rising White DW5725 bezel = #10273034 = $10.50
DW-5600C bezels 72101103 $5.50 backordered
DW-5600C straps 70360110 $7.00 backordered
DW-5600C case back gaskets 72045696 $0.50 in stock
DW-5600C spring bars 74276555 $0.50 backordered
DW-5600C bezel screws 74263948 $0.50 in stock
GW-225 bezel screws $1.00 backordered
GW-200 bezel screws $1.00 backordered
DW-5600 face protectors (silver) = #10065796 $5.00 in stock
DW-5600 face protectors (black) = #74299032 $3.50 in stock
DW-5600E end pieces 74243710 $2.00 in stock
G-5600 face protectors 10155555 $4.00 backordered
DW-6600 replacement band = #74210703 = $6.50
G-9000-8V Mudman band: part #10237944: $13 & bezel: part #10237940: $13
Originally Posted by Buzzbait View Post
The Fifa is basically a white DW-5600e, and a DW-5600E bezel and strap will not fit on a GW-5600.
Here's a breakdown:
DW-5600C, DW-5200, DW-5000 etc: These old steel screwbacks use a bezel and strap that is only compatible with these old models.
DW-5600E, and all plastic cased squares that use the 1545 module: They all use the same size bezel and strap. There are a million and one Casio variations on this theme.
G-Shock reissue screwbacks (DW-5000 reissue, DW-5025 reissue, etc): Steel cased screwbacks, based on the 1545 module. They use the DW-5600E bezels and straps.
G-5600 Tough Solar: Use it's own special bezel, but does use the DW-5600E strap
GW-5600 and DW56RT: Use their own special bezel and strap
GWM-5600: Uses its own special bezel, but uses the DW-5600E strap.
G-Shock end pieces will work on a DW-5600E (or variant), G-Shock reissue screwback, G-5600 or GWM-5600. They will not fit properly onto a GW-5600, a DW56RT or an old DW-5600C style screwback.
