there is regular time, and there is railroad time~
only 2 hrs late, thats a record for on time~
Lol, disregard.Module
Sent from my SM-G965U using Tapatalk
Anybody?Sorry if i post in the wrong thread. Do are there any other differences between the original band from GW-5000 & GW-5000B apart from the DLC buckle? It is the same soft urethane, the same colour?
https://www.tiktox.com/gw-5000-1-band.html
https://www.tiktox.com/gw-5000b-1-band-2926.html
Thank you
Thanks for this!PacParts recently re-added vintage square bezel screws available for purchase. Part number has not changed (74263948).
https://www.pacparts.com/part.cfm?part_no=74263948&mfg=Casio
Also available and have been for some time are genuine vintage square straps, but only in the gold buckle variant (70360128).
https://www.pacparts.com/part.cfm?part_no=70360128&mfg=Casio
The rear O-ring is also still available (72045696).
https://www.pacparts.com/part.cfm?part_no=72045696&mfg=Casio
Finally, the available washer part (72041011) is the tiny metal washer that is part of the button assembly. It is NOT the rubber cushion between the module and the case back.
https://www.pacparts.com/part.cfm?part_no=72041011&mfg=Casio
The newly re-added vintage square bezel screws are indeed the correct ones for DW-5000C-1A, DW-5200, DW-5600C-1V, et al.
How do I know?
I ordered some and then did a bezel screw comparison between bezel screws from a DW-5600E-1V, existing vintage bezel screws I already had on hand, and the newly acquired vintage bezel screws from PacParts.
See below for some pics of this comparison.
Left to right in the following 4 pics: DW-5600E-1V // Vintage square bezel screw from PacParts // Vintage bezel screw already on hand
As a final test of the newly acquired vintage bezel screws from PacParts, I installed them into a DW-5600C-1V case without incident.
For all the vintage square (and 5400/5700) restorers out there, hope this helps!
