Casio Pro Trek Tough Solar Triple Sensor 100m Watch PRG-110 1VDR
The latest 2007 release from Casio. Functionality-packed, Tough Solar, 100m water resistant and only 11mm thick!
Black, digital dial with resin strap and stainless steel case-back
Features:
Accuracy at normal temperature: ±20 second per month
Timekeeping
Hour, minutes, second, year, month, day, day of the week
Time format: 12hour or 24 hour
Calendar: Full auto-calendar pre-programmed from the year 2000 to 2099
Other: 3 display formats (Day of the week/day, date, barometric pressure graph); Home City (can be assigned one of 48 city codes);
Daylight Saving time (summer time)/ Standard time
Digital Compass
20 second continious measurements
16 directions
Angle value 0° to 359°
calibration (bidirectional, northerly)
4 direction pointers
Magnetic declination correction
Bearing memory
Barometer
Measurement and display range: 260 to 1,100 hPa/mb (or 7.65 to 32.45 inHg)
Display unit: 1 hPa/mb (or 0.05 inHg) 1hPa = 1mb
Measurement Timing: Daily from midnight, at two hour intervals (12 times per day); every five second in the barometer/thermometer mode
Other: Calibration; manual measurement (button operation);
barometer pressure graph
Thermometer
Measurement and display range: -10.0 to 60.0°C (or 14.0 to 140.0°F)
Display unit: 0.1°C (or 0.2°F)
Measurement Timing: Every five seconds for the first
three minutes after entering the Barometer / Thermometer Mode
Altimeter
Measurement range: -700 to 10,000 m (-2,300 to 32,800 ft) without reference altitude
Display range: -10,000 to 10,000 m (or -32,800 to 32,800 ft)
Negative values can be caused by readings
produced based on a reference altitude or due to
atmospheric conditions
Display unit: 5 m (or 20 ft.)
Other: Reference altitude setting; altitude graph; altitude differentia; altitude measurement type
Bearing Sensor Precision
Direction: Within ±10°
Values are guaranteed for a temperature range
of -10°C to 40°C (14°F to 104°F)
North Pointer: Within ±2 digital segments
Pressure Sensor Precision
Precision is lessened by strong impact to either
the watch or the sensor, and by temperature extremes
Temperature Sensor Precision
±2°C (±3.6°F) in range of -10°C to 60°C
(14.0°F to 140.0°F)
World time
30 cities (29 time zones)
Other: daylight saving time/standard time
Stopwatch
Measuring unit: 1/100 second
Measuring capacity: 23:59'59.99
Measuring modes: Elapsed time, split time, two finishes
Countdown timer
Measuring unit: 1 second
Countdown start time setting range: 1 minutes to 24
hours (1 hour increments and 1 minutes increments)
Alarms
5 daily alarms
Hourly time signal
Dimensions:
Case diameter: 46mm
Weight: 50g
Shipping: Free Shipping
Rate:
US $
175.00
Click here for more Watches: Casio pro trek watch
Click here for more details:
Casio Pro Trek PRG-110
Creationwatches
