Casio Protrek Titanium Triple Sensor Tough Solar PRG-90-1VDR
Altitude Differential Pointer : A pointer on the display shows the difference between your current altitude and the last altitude measurement. This information helps to determine your pace while mountain climbing or hiking.
Barometric Pressure Differential Pointer : This pointer shows the relative change in barometric pressure between the current reading and the last reading.This means you always have the most up-to-the-minute information at your fingertips, which gives you a very good idea of upcoming weather conditions.
A Wealth of Memory Data
- High Altitude
- Low Altitude
- Cumulative Ascent
- Cumulative Descent
- Relative Altitude (Change from a start point)
- Total Ascent/Total Descent
- Historical High Altitude/Low Altitude
- Digital Compass
- The first TRIPLE SENSOR model with WORLD TIME
- Metallic Grey with Resin Strap
- Protective metal front bezel
Electro-luminescent backlight
Full auto EL light, afterglow
Solar powered
Low-temperature resistant (-10 C/14 F)
Digital compass
Measures and displays direction as one of 16 points
Measuring range: 0 to 359
Measuring unit: 1
20 seconds continuous measurement
Graphic direction pointer
Bidirectional calibration and northerly calibration function
Altimeter
Measuring range: -700 to 10,000 m (-2,300 to 32,800 ft.)
Measuring unit: 5 m (20 ft.)
Auto memory measurements
(up to 40 records, each including altitude, month, date, time)
High Altitude / Low Altitude Memory
Cumulative Ascent / Descent Memory
Relative Altitude Display
Altitude Tendency Graph
Altitude Differential Graphic
Altitude alarm
*Changeover between meters (m) and feet (ft)
Barometer
Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg)
Display unit: 1 hPa (0.05 inHg)
Atmospheric pressure tendency graph
Atmospheric pressure differential graphic
*Changeover between hPa and inHg
Thermometer
Display range: -10 to 60 C (14 to 140 F)
Display unit: 0.1 C (0.2 F)
*Changeover between Celsius ( C) and Fahrenheit ( F)
Duplex LC display
World time
29 time zones (30 cities), city code display, daylight saving on/off
1/100-second stopwatch
Measuring capacity: 9:59'59.99''
Measuring modes: Elapsed time, split time, 1st-2nd place times
Countdown timer
Measuring unit: 1 second
Countdown range: 60 minutes
Countdown start time setting range: 1 to 60 minutes (1-minute increments)
Others: Auto-repeat, progress beeper
Daily alarms - 5 independent daily alarms
Hourly time signal
Battery power indicator
Power save function (automatically disables LCD if the watch is left in the dark for approximately 60 to 70 minutes, and sensor measurements if the watch is left in the dark for six or seven days)
Auto-calendar (to year 2099)
12/24-hour format
Regular timekeeping: Hour, minutes, seconds, pm, month, date, day
Accuracy: 15 seconds per month
Approx. battery operating time:
6 months on Rechargeable Battery (Operation period with normal use without exposure to light after charge)
21.5 months on Rechargeable Battery (Operation period when stored in total darkness with the Power Save function ON after full charge)
Size of case / total weight : 64.0 X 48.9 X 14.4 mm / 83g
Shipping: Free Shipping
Rate: US $220.00
Click here for more details: Casio Protrek Titanium
Creationwatches
- High Altitude
- Low Altitude
- Cumulative Ascent
- Digital Compass
Solar powered
Digital compass
Measuring unit: 1
Altimeter
Altitude alarm
Barometer
Thermometer
Duplex LC display
World time
Countdown timer
Hourly time signal
12/24-hour format
Rate: US $220.00
Creationwatches
