Casio Protrek Triple Sensor Tide Graph Tough Solar PRG-130-1V PRG130-1V PRG130
Features:
PRG-130 PROTREK outdoor watches with built-in compass, barometer, altimeter, and thermometer functions, with a tide graph and 200m water resistance added just for ocean lovers.
The PROTREK series of outdoor watches make the most of Casio's cutting-edge sensor technology to measure and display all sorts of natural data. The series is extremely popular not only with people who enjoy serious mountain climbing, but also with leisure-seekers such as those who like trekking and car camping.
In addition to their triple sensors for the measurement of compass bearing, atmospheric pressure/altitude and temperature, the PRG-130 watches introduced today are also equipped with a tide graph function and 200m water resistance, which are very handy for use on any body of water.
The PRG-130 watches come with a wide variety of other functions, as well. The moon data function displays the lunar date and the phase of the moon, and the timer function can be used, for instance, to time yacht race stages. The auto EL light illuminates when you lift your arm to look at the watch. The Tough Solar high-capacity solar-charging system, which generates power even in the low light of a fluorescent lamp, is another outstanding feature.
The watches incorporate a wide-viewing angle LCD, which make sure the data display is highly visible. The large metal function buttons on the side are designed for ease of operation even with gloved fingers. They are also treated with a grey ion plating finish that resists corrosion and abrasion, and a urethane surround helps make sure they do not get pressed accidentally. The register ring used with the compass function is knurled and inscribed with all compass directions, further enhancing functionality.
Tough Solar - Solar powered
Digital : Hour, minutes, seconds, month, date, day
Water Resistant : 200 Meter 20 Bar
Case diameter : 56.2 x 50.6 x 13.9 mm
Stainless steel Case. Resin Band
Scratch Resistant Mineral Glass
Auto Electro-luminescent backlight with afterglow
Digital Compass
20 second continuous measurements
16 directions
Measuring Range: 0°to 359°
calibration (bidirectional, northerly)
Magnetic declination correction
Bearing memory
Barometer
Display range: 260 to 1,100 hPa (7.65 to 32.45 inHg)
Display unit: 1 hPa (0.05 inHg)
Display unit: 1 hPa/mb (or 0.05 inHg) 1hPa = 1mb
Altimeter
Measuring range: -700 to 10,000 m
Measuring unit: 5 m (20 ft.)
Atmospheric pressure tendency graph
Atmospheric pressure differential graphic
Thermometer
Display range: -10 to 60°C (14 to 140°F )
Display unit: 0.1°C (0.2°F )
Tide Graph
Moon Data (moon age and phase graph)
Tide Graph (Tide level for specific date & time)
World Time (29 Time Zones, 33 Cities)
1/100 Sec Stopwatch : 23:59'59.99''
Measuring mode: Elapsed time, split time, 1st-2nd place times
Countdown timer : 1 sec to 60 minutes
5 Daily alarms
Hourly time signal
Battery power indicator
Power save function
Auto-calendar (to year 2099)
12/24-hour formats
Accuracy: +/-20 Seconds per Month
Solar Powered
Battery Life: 6 months reserve once fully charged
Module : 3135
Manual : http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=3135
Dimensions:
Weight : 78 g
Shipping: Free Shipping
Rate:
US $
210.00
Click here for more Watches:
Casio protrek
Click here for more details: Casio protrek PRG-130-1V
Creationwatches
