1 - 20 of 62 Posts
Of all the watches that caught my attention over the years, none quite had the mystery surrounding them like the Citizen Astrodea. I waited for several years before buying one, in part because I was hoping Citizen would come out with an Eco-drive version. I had decided I don't want more battery powered watches.
When I learned a bit more about the watch, I realized that the need for clarity on the printed metal dial would make it hard to use the translucent plastic found on solar watches. I searched the Forum and could only find one thread on this watch, in the high-end quartz forum. There was some good information there, but I still felt puzzled.
I figured a novice review could help, for those few people who might be curious about this little instrument. I'll give a good short-cut and some explanation, without using all the astronomical terminology. I might have understood some of those terms 30 years ago, but I forgot enough that I needed to start from scratch to understand this thing.
First impressions:
There are several versions of this watch, three latitudes (50°N, 35°N, 35°S), two sizes (38mm, 42mm) and two face colors (blue, yellow). I chose the 42mm yellow face for 35° north, a good match to my location at 37°N, in the San Francisco Bay area. The watch has sapphire crystal, on a low profile stainless case with a pop-top back to swap the silver oxide battery every 2-3 years.
The Astrodea arrived in its blue clamshell box, with pillow, Japanese instruction book, a 10x loupe, and additional English instructions provided by the USA eBay seller (Watchdesign.com). It came on 22mm solid link bracelet, decent quality, but I promptly replaced the bracelet with a shell cordovan strap out of personal preference.
My initial impressions of the build quality were slightly mixed. No flaws, it just didn't quite have the "wow" factor in terms of materials, that the amazingly detailed face had led me to expect. It is rather lightweight, which I enjoy, but I realize I also like that subtle feeling of heft from a thicker-walled case. The star chart dial and the chapter ring are made from die-cut sheet metal, micro-printed with all the elements of an astronomy device. The resolution is impressive. However, the color of the face is basically light yellow, and I couldn't help but think of the Japanese metal robot toys from childhood. That metal robot association takes away some of the sense of a precision instrument.
Regarding the color, I like the yellow dial because it's much easier for me to read than the midnight blue dial. However, I think I prefer the over-all appearance of the dark blue. The constellation lines get lost on the dark blue background, while everything shows up very clearly on yellow. The yellow does not have the sophistication, though, it looks more like a scientific instrument and less like jewelry.
During my efforts to learn how to set the watch, I came to feel that it is not quite the precision instrument that its face implies. The star chart dial has a certain amount of mechanical play from the gear teeth, especially as it tracks the hour and minute hands when I change time manually. (I think for this reason the instructions often mention moving the hands past the desired point, then returning back, while setting.) The three position crown is quite small, and it sometimes shows strong resistance when clicking to the outer position to set the time. On the contrary, the middle click for setting the star chart is quite subtle, and often I am not sure if I have pulled it to the correct spot. Hopefully these movements will smooth out a bit with use.
These are minor quibbles from a perfectionist, though. The main attraction on the Astrodea is the incredibly detailed star chart on its dial, and its unusual ability to track sidereal time on the retrograde dial, alongside solar time.
A few definitions:
I had to remind myself of some terms before I could understand the instructions. I hope this review can fill a need for more simple basic instructions for the watch. I'll risk being less precise here, for added simplicity. Many thanks to Wikipedia, which provided some of the following, quoted or paraphrased (Sidereal time - Wikipedia, the free encyclopedia)
Sidereal Time: measured relative to the stars rather than the sun. Because we turn once around the sun each year, that counts as one extra rotation relative to the stars, so we have 366 sidereal days in one year of 365 solar days. A sidereal day is approximately 23 hours, 56 minutes, 4.091 seconds (23.93447 hours or 0.99726957 mean solar days.)
(Wiki further explains: A solar day is, therefore, nearly 4 minutes longer than a sidereal day. Because the Earth orbits the Sun once a year, the sidereal time at any one place at midnight will be about four minutes later each night, until, after a year has passed, one additional sidereal day has transpired compared to the number of solar days that have gone by.)
Meridian: In the sky, the meridian is an imaginary line going from north to south that goes through the point directly overhead, or the zenith. On the Citizen Astrodea, the meridian line goes vertically between 12 & 6 (it is located on the clear transparency that stays fixed while the star chart turns underneath it, counterclockwise, at sidereal time.)
Solar Mean: the line that the sun appears to trace as it "moves" through the sky.
The dial:
The face of the Astrodea shows the information defined above, along with over a thousand stars and major constellations, on three layers of the watch face. Of course, it's still a watch, so it has standard hour, minute and seconds hands. The hands do not have lume, unfortunately, but they have a nice teal blue color that shows up clearly on the gold dial. (The blue dial version has white-tipped hands, I do not know if they have lume on their tips.)
The uppermost portion of the dial is a fixed chapter ring around the outside edge, with squares marking the 12 hours, and small hatches for minutes, above the names and numbers for the twelve months. At the lower edge of this ring is a very finely divided track which marks the days of each month. Slightly thicker lines mark the days numbered 1,11,21.
The next layer down on the dial consists of a transparent overlay that does not move, showing: the vertical meridian line between 12 & 6; the oval horizon line at 35° latitude marked with directions of the compass; an outer ring marking the twilight hours when a glow still occurs after sunset or before sunrise; and declination lines going up to the zenith overhead (the sky-chart equivalent of longitude and latitude.) Inside of the horizon ring marks the visible sky, and outside of this ring marks the stars that are hidden behind the horizon.
(Gearing for the watch face)
The main face of the dial shows the planisphere disk, and it moves in a counterclockwise direction, marking the sidereal day. It turns once every 23 hours, 56 minutes, 3.9 seconds (This would give a built-in error of about .2 seconds per day, probably limited by crystal oscillation rate and gear ratios, and is smaller error than the rated accuracy of the quartz movement at ±20 sec/month.) It moves counterclockwise because it shows the relative apparent motion of the sky opposite to the earth's clockwise rotation. This main dial has a huge amount of information packed onto it, including major constellations, visible objects of magnitude 4.5 and brighter, their different color types, and the sidereal hour markers around the edge. It also shows the solar mean disk marked with the numbers of the month. I found this solar display to be the easiest way to set the watch.
An easy way to set the star chart:
I must confess that I got a bit confused trying to understand the different approaches to using and setting the planisphere disk. Because it doesn't turn at the same rate as the 12 hour hands, it soon becomes clear that we need a calibrated start point, so the dates make sense along the edge as sidereal time slips earlier by 4 minutes each day. You can do this by calculating the longitude where you are standing, subtract 4 minutes per degree from 0° longitude (Greenwich) then find the correct settings for January 2 of the year. That gets really complicated.
I found a little gem hidden away in the technical manual for the Citizen 4391 watch caliber. It explains a short cut using the date markers on the Solar Mean disk and published sunrise information for your current location. Here are simple steps:
1) Look up the sunrise time for your city, for today's date. Websites will show this, as will the weather page of a newspaper (remember those?)
2) Pull the crown all the way out, and set the hands to reflect the time of sunrise. In my example below I use July 11, 2011, with sunrise at 5:57 AM.
3) Look closely at the light blue Solar Mean disk, and you will see numbers from 1-12 corresponding to the months, and gaps in the line, between the month numbers, corresponding to dates 11 and 21.
4) Push the crown all the way back in, and then pull out slightly to the middle position to rotate the star disk. Rotate the disk counterclockwise until today's date on the Solar Mean lines up to the Eastern horizon line, corresponding to sunrise.
5) Pull the crown back out all the way to time-setting position, and back the minute hand up by about 20-30 minutes, then move the time forward again, back to sunrise (5:57 in the example.)
6) Check the solar mean to make sure it didn't slip after this time adjustment. Repeat the above procedure if it did slip. Once satisfied, move the time ahead to the current time on the same day.
You can see from the pictures below that once I set the correct sunrise time for my date, I can track the position of the sun from the watch dial by tracking the motion of today's date, on the Solar Mean disk, as the watch face turns. At noon, you can see that 7-11 (July 11) crosses the meridian line close to the zenith. Later, at around 2:15 in the afternoon, it has moved towards the western horizon, and it should cross the sunset line (WNW) around 8:31 PM.
As the seasons progress, I will see these times change as the earth's position changes relative to the sun. In the meantime I can locate today's date on the outer chapter ring, and learn what the current sidereal time is relative to UTC. That would be useful if I wanted to calibrate a telescope, for example, or decide when to send a satellite into space.
I hope this didn't completely bore you. I thought a resource like this might prove helpful for those nutters like me who enjoy these sorts of toys.
All the best - Robert
Affordables Moderator
Great review of a complex subject along with the watch Robert :-!
I've wanted one of those Citizens since I first saw them, but the price kept me away. I bought a YES watch instead because I do love the geeky time stuff like sidereal time, solar noon, sunrise and sunset times etc.
A beautiful watch. But although I am a very serious amateur astronomer and thus attracted to this device, I had to admit to myself that I would not find its functionality attractive for astronomy. Here's why.
1. The planisphere, while beautiful, is simply too small. Perhaps the 10x magnifier will ease that problem.
2. The way I use a planisphere is to check "what constellations are up at XX:XX o'clock". And XX:XX o'clock is almost never the current time. Rather it's next Friday night at 10:00 PM, or some other time in the future.
3. Obviously telling the time of day is a bit of a challenge.
Genuinely sorry indeed to be negative. Once again, it's truly beautiful. When Robert first told me it was inbound I wanted one too. I wrote to him, "Looks like something I should be interested in".
Sincerely,
Alan
Discussion Starter #4 (Edited)
Thanks, Griff! I love the features on the YES watch also. This was actually a bit cheaper than the Yes watches that I have seen online, believe it or not. (I got a good deal.) And, I just got seduced by the vintage-looking graphic detail, whereas the YES watches have more of a techie look with the LCD.
Discussion Starter #5 (Edited)
No need to worry about sounding critical, Alan. Your comments are well directed. Indeed the Astrodea has much more "cool factor" than it does practicality to an astronomer. But then, most could argue that dive watches were made obsolete by the dive computer, yet dive watches seem more popular than ever. Also, with your recommendation by PM, I tweaked a word or two up above, for clarity. I appreciate the feedback.
To address your 3 points: (1) Totally agree - the dial is very small for any practical use, although the loupe does help. In part, I think it's the miniaturization that makes the whole thing so cool.; (2) You can in fact use the planisphere for predictive viewing. You look up the sidereal time for the date you wish to view the sky, pull the crown out to the first step and rotate the sphere until the sidereal time lines up to the date of interest. Then, when done, you turn the disk back to the spot where it was before, corresponding to "now"; (3) It's actually quite easy to read the time. The hands are narrow, but show up very clearly on the dial, and the hour and minute markers are rather clear on the outside edge... but indeed there are no digits for the hours or minutes, and the date display is very tiny. Plus, using the date display assumes that you already know the date, and you use that info to line up the other functions. So, it's a different approach, certainly.
Thanks for contributing such thoughtful commentary! - Robert
Sincerely,
Alan
Nice review! And here is a simpler setting procedure....
The procedure is apparently described in the Japanese manuals for the newer calibers and you can also look at the first TWO posts from here but the procedure is basically:
1) Find out your local longitude; it is assumed that you know your local official time :-d
2) Calculate the Local Solar Time = remove any DST (solar or sidereal time have no DST) and add/subtract any fraction of longitude away from your 'base timezone longitude' - for instance I am at 26 degrees of longitude and my timezone corresponds to the time from a multiple of 15 degrees - meaning 30 degrees in this case; because of that my Local Solar Time is 26-30 = '-4 degrees away' = meaning -4 * 4 minutes = 16 minutes BEHIND the normal 'official time' in my timezone; during 'summertime' I am actually 1 hour 16 minutes behind;
3) Align the time found in the previous step (at the periphery of the inner ring).with the current date on the fixed outer ring.
4) Extra verification - read on the meridian line of the watch your Local Sidereal Time and see if that matches the value from this site = Local Apparent Sidereal Time :-d !
And as a small bonus - here is a picture of my own Astrodea:
Discussion Starter #7
Re: Nice review! And here is a simpler setting procedure....
Thanks for posting, Catalin! Indeed, your instructions were the first I tried, from the English translation of the new Japanese manual; and they drove me bonkers until I found the sunrise shortcut in the movement documentation. I absolutely love the look of your early blue dial version of this watch. I only wish my eyesight were better. I find the yellow dial a bit easier to read, although not as cosmic. Enjoy your lovely Astrodea! :-!
That is an amazing watch! It's rare you see anything with this much non-immediate survival information on it! (in other words, a nice change from temp / pressure / depth / remaining oxygen etc).
Wonderful review and beautiful watch. I've been thinking about picking one up myself.
One little correction on your eco-drive theory though. Various reviewers (prior to your article), including watch blogs, have developed a post-hoc explanation for the lack of eco-drive in many of the high end models. The reason given is that something about the dial didn't permit solar power to be used.
The actual reason is that this model, and most of the Campanola line generally, are using old quartz movements from the 80s and early 90s before they were using eco-drive. The Astrodea/Cosmosign are recent models, but actually are descendants of older models themselves. Many apparently opaque dials, from Citizen and otherwise, are still able to get enough light through (somehow) to the solar cells, although no doubt at diminished efficiency.
I wish they'd update the movements because the watches are so gorgeous. The Astrodea is reasonably priced, but many of the Campanolas, though beautiful, are bizarre in that you get a lower-end movement (in some ways) than a $100 Citizen.
Oh, and side request, can I get some more wrist shots? I've got pretty small wrists but I'm thinking about picking one of these up.
Discussion Starter #11
Thanks for this good information, CitizenM. It does seem likely that the Astrodea movement would come from older designs, as they have had versions of this for 15 years or so. I had been waiting several years for a solar version and finally gave up. That's OK, I can live with another battery change in my collection. However I do really doubt that they could get this resolution of printing on translucent plastic, and I can't think of a good way to pass light through sheet metal. To reply to your request for another wrist shot, here's a photo just after opening the package, with the bracelet still on the watch (unsized.) My wrist is 7", and the watch at 42mm fits quite well although it's at the larger end of my preferred size. This is one watch where larger is better though, as it gives just a bit more resolution to the dial.
Discussion Starter #13
Thanks for the kind remark, Turnaround! I was a bit flummoxed myself until I caught that tip about setting to sunrise, hidden in the movement documentation online. Once I saw that, several things fell into place for me.
Awesome, thanks for the wrist shot. It's a much better size than I had imagined...in my mind the thing was huge. The biggest impediment for me is I have that irrational love of automatics I just can't seem to shake. But I have a taste for the unusual and the unique. And the Astrodea clearly fits that bill. I don't know how the people around me that wear Rolex Day-Dates deal with everyone in the world wearing their exact same watch...
Discussion Starter #15
I sympathize in several ways with your thoughts. Likewise, I feel that mechanicals just have a bit more pizazz than quartz, but there's a time and place for different technologies. I also share your tastes for the unusual, which is why my watch collection has such a scattered sensibility to it! :)
I just came across this thread after discovering this watch a few days ago. I'm interested in purchasing it, but it looks like it's sold out everywhere I've looked. Does anyone know where a blue-faced, 35 degree north calibrated, watch might be (dial size doesn't matter)? Any help would be great.
Discussion Starter #17
They were never very common. I recommend keeping a search on eBay and look for one coming up. Good luck!
I agree!
Old post, but I'm looking for the same thing. They are quite rare. I'm thinking about getting one of the licensed "astrodea" watches. There is a blue 35N on ebay for cheap, but the printing on the crystal looks thick, and the dial has a lot of red that I don't care for. Accurist makes a blue 50N I'm considering. It's hard to tell from pics, but the dials on the 50N and 35N are the same, correct ? They just change the grid markings printed on the crystal ? The 50N looks rounder, while the 35N versions looks more oval. Which I guess makes sense. I'd rather have a genuine Astrodea, but I haven't seen any used ones for sale, and according to a thread on a Russian watch forum, when they do come up, they go for $750 and up. The new one from Accurist is about $350 with the metal bracelet. It's not as good as the genuine thing, but it looks nicer than the $175 one on ebay.
Discussion Starter #20
The Accurist model was around back when I found my Astrodea, and indeed I thought it looked pretty good, but not quite as crisp and detailed as the Citizen. At the time I bought my Citizen, it was almost the same price and almost as hard to find. Be careful about the cheaper ($100-ish) version on the Science Watch Store (watchdesign.com), the printing looks very low resolution and the star chart rotates manually from an extra crown, not connected to the movement at all. It has the look but not the technology, which is a good compromise if you only want the look. Interestingly, that's the same seller I bought my Astrodea from three years ago, but they only had them for a short time as I presume they were too expensive for people. I bought mine when they were discontinuing the item and dropped the price - I guess I got lucky.
1 - 20 of 62 Posts
