1 - 11 of 11 Posts
Removing plenty of seiko bezel is almost my daily activity, so i assume NY0040 may use the same technique.
But unfortunately I never been able to remove this Citizen bezel...
Been using many ways, from single knife, double knfe, thinner knife.. nothing work.
The bezel didnot even pop a bit... and worst i made scratch and mark during the attempt.
I wonder if anyone can guide me in removing the NY0040 bezel
I just figured it out!
Insert fingernail (or something) under bezel. Don't use much force, so the bezel rotates easily. Rotate bezel until You find spot where bezel lifts bit more. At this point insert fingernail deeper and rotate bezel until it pops out (in around 1/4 turn). Mine was pretty hard to rotate, I had to use rubber covered pliers, but managed to remove it without damage. Maybe some lubricant would be helpful (silicone oil is safe choice).
Point is to find where is the spring opening. I believe the spring rotates along with bezel, so there is one spot of bezel ideal for lifting.
Watch Fashion accessory Wire Metal
Hi THX1138,
Thank you for the tip, in the end you interpreted correctly the "Remarks", orange color print, from the Citizen Instructions:
"It can be removed easier by turning the register ring and opening the place where the upper and lower play is the greatest."
Another trick I used is to place a plastic credit card or a plastic business card as a shim and hold the bezel in place lifted, while
prying the adjacency gap.
Cutting a radius "U" shape equivalent to the bezel radius on the card will help to get more bezel area.
Also making a edge knife profile on the card helps greatly to slide in the gap.
Best regards.
I know this is an old post, but I wanted to share what I did for anyone searching. If your objective is just to remove the insert, you can just soak your watch crystal down in a little of WD40. I read you can use golf club grip remover, but I didn't wan to to purchase an entier bottle just because I had a misalinged bezel.
1 - 11 of 11 Posts
