Hi,
Unfortunately due to breaking one of my stock spring bars for my 104 I had to order standard 20mm spring bars. The new bar I am using doesn't seem to fit the lug hole properly and now clicks when the watch strap is pulled away from the lugs.
Please could someone tell me the correct size (thickness at ends) of spring bars to but for the 104? I noticed also that the ends of the spring bars I ordered were a different shape and also had two grooves for catching the spring bar tool, instead of just the 2 in the stock Sinn bars.
Just call Watchbuys and order a pair of Sinn bars. But, I think they are 1.5 or 1.8.
I've noticed it too. The OEM spring bars are more rounded at the tip, unlike other spring bars. Maybe it's the way the holes were drilled??
Even my original spring bars that came with my U1 on the leather strap do that. I think its just normal play however. But listen to Geof3. Ask them about the original Sinn ones.
