Comrades, I am in need of help understanding Vostok Amphibian crystals.
I have a Soviet 470 which I acquired recently & decided to give it a thorough cleaning. In so doing, I removed the crystal and cleaned the inside rim of the case where the crystal sits. After polishing the crystal I reinserted the tension ring within the crystal and reassembled the case using all the same parts save for new crown & caseback gaskets. I then tested for water resistance in 5" of water - sadly the empty case took on water within seconds. I'm rather certain the ingress is at the crystal as the crown & caseback were quite tight. I took it apart, flipped the tension ring within the crystal around the other way & reinstalled with crystal press, hearing a satisfying snap in the process. Same water test, same results. I went through this a few more times, always with the same results. Very sad.
Next I dug out some of my spare amphibian crystals and tried to insert them. I couldn't get a single one to fit, their diameter was too great. I measured the extant crystal - 31.1mm. All the spare crystals I have measure 31.5/6/7mm. What the Stalin? That's quite a difference! Now, I'm not entirely certain where I have acquired some of these crystals, I know 1 or 2 have been sent along with dials from Amil, but they all exhibit the same Amphibian thickness with the same dome & generally the same height. The only size listing for an Amphib. crystal I can locate is from Favinov at 31.2mm for a new one.
Setting aside my confusion over crystal sizing, how can I reinstate a measure of WR? While I was cleaning the crystal rim on the case, I was removing white powder which I assume is old glue. Is it necessary to glue these in to retain WR? I did not believe this to be the case, but if so, is a substantial bead of GS Hypo cement sufficient? I won't be scuba diving but I don't want to worry about every little drop of water, which I currently would. I really don't want a new crystal as they have a pronounced shoulder from the crystal to the bezel; these Soviet crystals have a nice smooth transition (no shoulder) from crystal to bezel.
Also, the tension ring appears to be beveled on one edge, what is the proper positioning of this?
Help me Obi-WUS, you're my only hope!
Patient Zero:
Patient Zero:
