Which one is better ?
But since the OP opted to come ask here instead, let us regale him with some extra (secret) info that is not readily available online: ;-)4R36 has manual winding and hacking. Beside that, they're identical.
You would have immediately found this answer with a search.
SII is Seiko Instruments International. Same product, same Japan factory, different label.I'm sure you are aware the 4R36 is a clone of the SII NH35?
Time to write an innocent question 30 sec, time to write a funny reply or debate 3 min, which one is wasted more?I hope you've learned a valuable lesson...refrain from asking innocent questions here. You will be mocked and ridiculed. In other words, you wasted your time.
A quick search on the subject will tell you that 7s26C and 4r36A movements are completely the same, apart from the hacking and handwinding. Mechanically the same. Same part numbers for everything remotely related to accuracy.... but the 4R is definitely less accurate. so you decide whether losing accuracy for those features is worth it to you.
Just have the watch regulated to eliminate the luck factor. It is not difficult nor expensive.And having owned the 7S26, 4R36 and 6R15, the 7S26 is the best deal of the bunch. They're all a toss of the dice on accuracy.
