<center>
<a href="http://i99.photobucket.com/albums/l285/Dan_Spend/zno.jpg" target="_blank">
<img src="<A href="http://i99.photobucket.com/albums/l285/Dan_Spend/th_zno.jpg"></a">http://i99.photobucket.com/albums/l285/Dan_Spend/th_zno.jpg"></a>
<a href="http://i99.photobucket.com/albums/l285/Dan_Spend/zenowrist1.jpg" target="_blank">
<img src="<A href="http://i99.photobucket.com/albums/l285/Dan_Spend/th_zenowrist1.jpg"></a">http://i99.photobucket.com/albums/l285/Dan_Spend/th_zenowrist1.jpg"></a>
<a href="http://i99.photobucket.com/albums/l285/Dan_Spend/zeno1.jpg" target="_blank">
<img src="<A href="http://i99.photobucket.com/albums/l285/Dan_Spend/th_zeno1.jpg"></a">http://i99.photobucket.com/albums/l285/Dan_Spend/th_zeno1.jpg"></a>
<a href="http://i99.photobucket.com/albums/l285/Dan_Spend/zeno.jpg" target="_blank">
<img src="<A href="http://i99.photobucket.com/albums/l285/Dan_Spend/th_zeno.jpg"></a">http://i99.photobucket.com/albums/l285/Dan_Spend/th_zeno.jpg"></a>
<br><br>
</center>
ZENO ARMY Automatic Retro Diver Orange
The Retro Scuba Diver Timekeeper (with integrated bracelet)
Case
diameter 40mm - thickness 17mm - 316L stainless steel, bead blasted bracelet and watch case by
engraved solid stainless steel unidirectional rotating no-decompression dive bezel with ratchet, screw-down winding crown and solid screw-on back
water resistant to 30 ATM (1000 feet), shock resistant, antimagnetic (tested for DIN 8308, DIN 8310, DIN 8309) - duoblock construction
The unidirectional turning bezel has two marks at 1200
Glass
vintage look domed acrylic crystal (extra thick)
Dial
orange with big luminous markers, Superluminova advanced lumination hands and numbers, tested for DIN 8306
Band
48M3I integrated stainless-steel bracelet with progressive width and strong deployment flip-lock buckle, double lock security clasp, massive links and solid attachments.
Movement
High quality Swiss Made mechanical/automatic winding. ETA 2452 -
21 jewels, Swiss lever escapement, Incabloc shock absorber, Glucydur balance, Nivarox flat spiral, Antimagnetic, 18´000 vibrations per hour, Nivaflex spring, ball bearing central rotor with heavy metal weight, power reserve to -35h
Watch is in 90 % conditionand keeping great time.
$299.00 shipped priority mail in conus.
<br><br>
</center>
Case
Glass
Dial
Band
Movement
