1 - 14 of 14 Posts
I purchased my GA800 new in September 2019. It has been my solid go to since purchase. The issue that I am experiencing I just noticed a hour or so ago. Normally when turning an alarm on or off the second hand will point to on or off. Which are below and above 9 respectively. Today it is pointing to on and 12. I wonder if this is a sign of low battery?
Sent from my SM-G981V using Tapatalk
Discussion Starter · #2 ·
I had the time to sit down earlier and try to figure out the issue. I wound up pulling the battery for about a minute. After I reset the hands and time, all is well.
What adapters for NATO straps will fit on the GA800??
rmeron, I assume it would be the standard casio adapters.
I am not telling you to buy these but this is the style I am referring to. They might be found cheaper elsewhere on eBay or somewhere else. I just pulled this link for the image.
Discussion Starter · #9 ·
I guarantee it.
With that much of a gap between the case lugs and the adapter that adapter will slide back and forth too much.
Discussion Starter · #11 ·
It does not slide at all. It has the same "wings" that the combi bracelet has for the 5610.
I'm glad it does not slide back and forth. I had a set up like that before with different watch and the adapter slid back and forth all the time and it drove me nuts.
Discussion Starter · #13 ·
Nope. It's designed with the same principal design as the factory straps & cpmbi bracelets. However I would strongly recommend nato straps or single pass, not 2 piece straps.
The adapters do have a little swing/flex/rotation forward & back. Hair could get pinched. Bit this also makes for a better overall fit with a single pass/nato.
1 - 14 of 14 Posts
