1 - 13 of 13 Posts
Does anybody know if they band and bezel off the GWM-5610-1 will fit on the DW-5000-1JF?
Thanks for any information!
If you are referring to DW-5000-1JF (Reissue) with module 1545 then the band is interchangeable with the GW-M5610. I suggest using the softer band from GW-5000.
However, their bezels are not interchangeable.
The bezels are not the same size. Here is a compatibility chart.
Thanks guys!
I am considering purchasing one of the reissue 5000s but would like to replace the bezel and band. Can't seem to source a new set so was hoping to swap from my 5610..
If you are getting a DW-5000 Reissue then look at a DW-5600e bezel and strap
Like here
https://www.ebay.com/itm/CASIO-G-Shock-DW-5600E-Original-Black-BAND-BEZEL-Combo-DW-5600V/252969172647?hash=item3ae6233ea7:g:WG8AAOSwqVBZalSN:sc:USPSFirstClass!21045!US!-1
The strap and bezel from a DW-5600e (a watch Casio has been selling for years(since the mid 1990's) ) is compatible
It should be cheaper to find them from other places but use the link as a reference
What is wrong with the band and bezel on the DW-5000? Those last for years
Discussion Starter #7
Like here
Thanks for that. So far that link you sent is the only one I can find for the set (I'll keep searching though).
PacParts seems to not sell the bezel and out of the band (for the 5600e).
To answer your last question, I'm not entirely sure if it WILL in fact need to be replaced as I have only seen pictures from the seller but make be some warping on the lug ends of the bezel and have wear on the resin. Just want to have some options to restore parts if needed. Hopefully it will just need a little cleaning.
Check Pacparts.com
I did check there but can't seem to find anything in stock for what I need (at least at the moment).
Here are some link from pacparts.
You can go with GW-5000 band which is much softer and comfy.
PacParts: 91087090203
You can put a more stealthy look with DW-5600MS bezel (all black), and cheaper too.
PacParts: 91087978518
or you can put a DW-5600HR bezel, the lettering is not that bold (white) as compare with the original DW-5000-1JF bezel.
PacParts: 91087201494
The link provided at ebay is so expensive....you better buy a new DW-5600E at Amazon.
https://www.amazon.com/Casio-G-shock-DW5600E-1V-Shock-Resistant/dp/B000GAYQKY/ref=sr_1_1?ie=UTF8&qid=1541373104&sr=8-1&keywords=dw-5600e
Discussion Starter #9
Aah thank you so much! Clearly I am terrible navigating through the PacParts website...
1 - 13 of 13 Posts
