Hi guys!
I recently bought a generic diver case with very similar dimensions to the 42mm width/13mm high Ocean One but I'm having a hard time finding a replacement bezel insert!
The insert has an inside diameter of 32mm and an outside diameter of 39mm.
Could you please measure one of your inserts to check if they're commpatible?
Thanks in advance!
The bezel on my Steinhart Ocean 1 DLC is approximately 32.3mm x 38.7mm
Thanks for taking the measurements on your watch! Even if the dimensions are not quite the same, I think I'll take the chances and order a bezel from Steinhart.
I would suggest you email Steinhart first to get the exact dimensions.
