1 - 20 of 73 Posts
I found this old thing (small mens watch) in a small lot of watches i baught in a auktion and need some help placing it in time.
As you can see it's got some condition issues with the crystal but in general it looks very nice
The dial is nice after all these years (age showes of course) but no branding on it.
Here is the strange part there is no information of the movements origin. There is usally at least the country name stamped like Swiss but nothing at all.
I tried to clean the crystal but it started to smell like earth an spearmint so I stopped. I thought this was a 50's watch but I now think it's older so any idés?
Vint. Forum Co-Moderator
Late 1920's through 1930's. The crystals always need changing on these. If you pulled the dial it would almost certainly show the manufacturer - I'm sure that Harmut will leap in here as he usually does with these movements but I'm going to go with A Schild. You might be able to peep under the dial as the markings are often close to the edge.
+1...late 1920s to early 1930s. As for the movement - I can't help.
Is the case solid gold? For all the wear it doesn't look brassed in the picture.
I like it - nice catch.
Thanks that was somthing I didn't know but I can't see any brand so I will have to remove the dial. I don't have a good hand remover so I have to buy a better one so I don't damage the dial.
Sorry only plate but it sure looks great.
Its an interesting looking watch - Dial looks like a clock with the inner 24 hour track
When you take the hands of, put a side from a small thin plastic bag over the dial.
The hand remover will grip underneath the plastic and you won't scratch the (metal) dial
Discussion Starter #6 (Edited)
Am I right in thinking this old silver watch is of the same era?
I thought is was a kids watch at first because of the painted numbers.
No it was a silver watch (First I have seen in real life). That is actually the full adress to the owner of the watch and I bet it was hit pride and joy.
At least it's Swiss made. :)
The engraving on the movement is that a manufacturers name or just some nice artwork?
Enamel dial (double sunk) so I think earlier than the OP. say 1920s. Engraving indicates (maybe) 23 = 1923 Very nice indeed. That is a good piece
I'd be inclined to say it's in the same 20-30's era as the OP's. This one has unusual dial-screws; not sure if that would be original or not. The crown wheel design reminds me of some Gallet's from that era. I suspect the markings on the movement were added by the owner; they look like they go through the gilding, whereas a makers mark would likely have been added before the gilding.
Discussion Starter #9 (Edited)
Thanks! The 23 is the owners street number so it's his full name and address.
It's a watch I was thinking of having repaired (To scary for me at the moment) so I can use it myself because it's the right size and very coulorful and funky.
Thats a great idea.
I love the cushion shape and the dial is fantastic
Try looking up the address??
Search out the owner.
I still think is a 20s timepiece
Great piece
Well worth repair for sure...I would think that you could date the case pretty closely based on the silver hallmarks...I don't know anything about Swedish hallmarks, but I would bet that someone does.
PS
In addition to my post above
That dial and hands are RADIUM.
Be VERY careful not to touch and get any pieces on your fingers -->then in your mouth.
RADIUM even 90 yrs old is very radioactive.
Be very careful
A
Sadly not
Unlike UK that has both a city mark and a year mark.
I am pretty confident 1920s
Discussion Starter #14
PS
Be very careful
A
Good catch!
I didn't know that and sure enugh all the number light up in the dark but not the hands.
Good catch!
Well put it this way
"Wash your hands BEFORE you go to the toilet"
Discussion Starter #16
Thankfully I havent opened the dial side of the watch so I should be safe but wonder where the radium on the hands have gone...
Scary stuff this but darn it look amazing in low light.
You will know when you can see your pea in the dark LOL
It lights up? Radium doesn't glow on it's own (well, it does but not very much, and if it's the radium that's glowing, get RID of that watch!!!). It's the phosphor that glows, and phospher breaks down very quickly due to the radioactivity, so most radium watches stopped glowing a decade or two after they were made. So if your watch glows presently, chances are it's been repainted recently.
Swedish? :) Swiss bear, so Swiss made most likely with German import marks - I assume that ties in with the address.
I'd agree with Rob, same age range as the previous watch - the cushion shape was much more 1930's than 1920's.
As for the movement I'd say FHF
Discussion Starter #20 (Edited)
After some time in darkness it stopped glowing so it's not radium.
Swedish?
Yes Germany was the main trading country for Sweden back then. So a watch made in Switzerland imported to Germany then exportet to Sweden is very plausible. Did Germany use 24 hour dials like we in Sweden used up into the 60's?
1 - 20 of 73 Posts
