1 - 13 of 13 Posts
Hey guys.
I've recently got the G-Shock bug with a G5600e on the way right now. I love how tool like G's are and think they look awesome it a practical way.
I have just a few questions/concerns and any input from you guys would be really appreciated. I realise that my concerns are probably unfounded or otherwise I would have found more information.
1. I'm planning on using some JaysandKays nato strap adapters.
Do you guys think that using adapters will cause premature wear on the plastic lugs? Has anyone really experienced broken lugs on a square?
2. Has anyone ever heard of the buttons ever wearing out, breaking or getting loose?
I tend to like simple designs as the less moving parts, the less chance of things getting broken.
I imagine the buttons and the lugs are the main bits that can wear out as nothing else in the watch really moves. I'm aware about resin rot but I'm not really concerned about it as spare resins seem pretty plentiful and it'd probably take a very long time for the resin to get to that point.
Thanks again guys.
1. No
2. No
Can’t go wrong with a solar G, once it is fully charged you just need to make sure it gets to sun bathe occasionally, don’t do what I did and shut one in a drawer and forget about it for 18 months, I managed to kill the rechargeable battery, it wouldn’t hold a charge after that, but a genuine CTL1616 battery was inexpensive and easily replaced and the watch was restored to its former glory.
I have used Js&Ks and the OE Casio adapters and apart from being fiddly to install initially had no issues including catching my watch up on a door handle!
I thought it would be mullered, fortunately although one of the spring bars was bent and had popped out a replacement bar easily sorted it.
As you said they are a fantastic tool and like all good tools you learn to love them, appreciate them and sometimes take them for granted until you have an accident that would kill another watch and your G shrugs it off.
Damage your G and you can easily replace most of the parts that are likely to wear, bezels and straps are easily sourced and swapped inexpensively.
Worst thing : start with 1 x G and you soon develop an unhealthy obsession and end up with 5, 10 or 300!
1. No
2. No
Can't go wrong with a solar G, once it is fully charged you just need to make sure it gets to sun bathe occasionally, don't do what I did and shut one in a drawer and forget about it for 18 months, I managed to kill the rechargeable battery, it wouldn't hold a charge after that, but a genuine CTL1616 battery was inexpensive and easily replaced and the watch was restored to its former glory.
Awesome.
That is super reassuring to hear.
I currently have some divers but I'm getting sick of constantly being worried about damaging them so I feel like a Gshock would be just perfect. Solar powered watches are just super, I have no problems with keeping them charged.
Haha that's probably what's going to happen. Give me a month and I might just have a handful of G's to choose from.
Here's another question - Do you guys bother with changing the gaskets and pressure testing them? I'd imagine with the cheaper g shocks it'll probably be more cost effective to just get a new watch (another reason to buy a watch!).
Awesome.
Never have bothered to change the gasket, I have however made sure that I use silicone grease around the seal.
Apart from a bit of pool swimming/showering my watches do not get that wet, certainly to no depth. Never had an issue with water ingress.
A new seal, like most spares, is easily sourced and cheap if you were worried, but a solar G shouldn't need to be opened for 10-15 years or more unless you plan to modify it.
If you're worried about diving and water/pressure proof of the watch try to find a full metal cased screwback model, a GW5000 would be fine for casual diving. Casio/G-shock market some great proper dive watches, but their size has always put me off.
No and no. In all the years I've worn a watch with a respectable WR I've never changed the gaskets or had it pressure tested. May I also add that none of my watches has ever let water in.
But what you didn't mention is whether any of your Gs are ever exposed to water... ;-)
:-d:-d:-d
Reactions: Steelerswit
The resin bezel case on my DW5200-C lasted from 1984 until 2007 and then it pretty much disintegrated and I bought a replacement. My button controls all work just fine but I am no longer confident about water resistance after 35 years of use. For that reason I am in the process of buying my second square G Shock watch. Of all the wrist watches I've ever owned and I've owned a bunch, the G Shock represents the smartest buy. The longevity is great and I think I paid 39.95 at a K Mart store when I got it.
I used it for 5 years on a patenting furnace and other jobs at a Bethlehem Steel Mill then 2 seasons of commercial fishing. I followed that up with 15 years in construction work as well as recreational use. They are great watches :)
1 - 13 of 13 Posts
