1 - 14 of 14 Posts
Hello,
Who do you recommend to refinish a Sinn156? Have a couple of scratches/scuffs that I am thinking of getting repaired.
Thanks for you help...
Comments from anyone who has actually had a Sinn refinished would be great.
Charles
Hello,
Charles
Where are you located, Charles?
Jack at IWW is the obvious choice then, but as your watch will have to cross borders anyway, you might also consider Bry at http://www.satintime.co.uk/, and I think Duarte in the US does work in this field, too (does Duarte have a website?).
Duarte: http://mysite.verizon.net/dmendonc/northeastwatchworks/index.html
Also, a friend recently had a great job done on his 156 by Herr Sinn at his shop in Frankfurt.
DW
Discussion Starter · #7 ·
Thank you guys for your responses. I am having the watch sent to IWW to have the case refinished.
The link for Duarte was very interesting, I didn't realize that you could have a watch two-tone bead blasted.
My concern is that the tone of the watch's original finish is changed. Jack mentioned that he has refinished Sinn watches before and actually has previously had a Sinn156. I will post pics here when it is done.
Thanks
Charles
Charles,
Jack should have no problem refinishing the Sinn to factory spec. I've just refinished a Sinn Ezm2 which has the same finish, you can either sandblast to get the correct finish or use a mix grit. Sandblastnig is banned in the UK, so I used a special mixed grit mix.
Look forward to the results.
Regs
Bry
Martin Silica is a Carciogen,
Use of silica in sandblasting continues to be allowed in North America, while it was banned in the UK in 1949 and in Europe in 1955.
Regs
Bry
1 - 14 of 14 Posts
