1 - 3 of 3 Posts
I got a new Oris Diver Date about 2 mounths ago. Great precise watch that i really love...
anyway, in the past days i saw some stains (fade yellow) on the watches case. how i get rid of them?! the watch is bearly sees water! i only wash hands with it and then rinse the soap....
It's highly doubtful that the stainless steel has become stained. It's probably residue of something on the case. I will occasionally spray some mild bathroom soap scum remover on a watch case and give it a light scrub with an old toothbrush before rinsing it off under the tap. This usually removes all the residue from the case and bracelet (don't spray it on leather straps).
As usual Brent is spot on. I would start with a bit of shower gel first to see if that does the trick before moving onto something a bit stronger like Brent suggested. Be sure to give it a good rinse whatever you end up using.
1 - 3 of 3 Posts
