Help to Identify Tag Heuer Professional 1000 Dial
975 Views 2 Replies 2 Participants Last post by  MUA
2
Hi, I'm going to purchase a Tag Heuer Professional 1000 watch from a trusted seller.
The lume on the dial seems to have a rough finishing which irritates me; particularly, please see the lume at 6'o clock position which is not in the center as that at 9'o clock position, does it look normal?
The seller told me that the dial is genuine and lume is standard from the factory.
As a general perception, I believe it should be nicely finished, especially for a watch from an established brand like Tag Heuer. Also, I've seen few images for this watch available on the internet and could not find such issue.
Thoughts from fellow members would be highly appreciated. Thanks!
Watch Analog watch Light Product Clock
White Watch Font Clock Measuring instrument
1 - 3 of 3 Posts
It's clearly offset but the overall appearance seems legitimate to me. It looks like I'd expect an expired tritium lume to look. If it were me and I just wanted that watch, I'd assume the lume to be expired and I'd let the offset issue stand as is. If your eyes go to it every time though, that would likely irritate you too much so I'd probably pass. If, instead, you have a good local guy who can re-lume it, that's all you'll need to do and make sure he gets it centered.
The problem with such things is, if you know it's there (and you're the only one who notices it) you'll always fixate on it and you won't be happy. So it's probably a pass. You will likely find another better one down the line so no need to grab this one. But, if you've been looking and this is the only one you've seen in months or longer, maybe you have to lower your expectations and get it anyway. It really is a coin flip!
You should definitely ask for more pictures including some of the movement (this is quartz so you're not gonna see much) so you can confirm it's an actual OEM movement.
Reactions: 1
@kevinkar
Thank you for your detailed response and kind advice. It is very much appreciated!
1 - 3 of 3 Posts
