Vendor
Welcome to the WatchObsession Store
HIRSCH EXTREME RUBBER DIVE STRAP in
BLACK, BLUE & ORANGE.
Extreme's fascination lies, not least, in it's extravagant styling with overlapping segments that ensure extreme extensibility,
and in it's tensile strength, dimensional stability and resistanceto external infuences that are ensured by the natural rubber developed by Hirsch.
Upper Material : Caoutchouc, Natural Rubber
Features: Stunning Comfort & Radical Design
Widths : 20mm, 22mm & 24mm
( All straps taper and are 2mm narrower at the buckle )
Strap Length ( excluding buckle ) 120 / 80mm approx.
Complete with replacement Spring Pins
Warranty: Hirsch is the only manufacturer of watch straps to grant an extended warranty of One Year for the Leather Straps.
Hirsch will replace any strap that shows faulty workmanship within the first year of purchase.
Cost £ 55.95 including UK Delivery
Overseas £ 4.95 shipping.
Buy Direct from WatchObsession, click link below
http://www.watchobsession.co.uk/shop/advanced_search_result.php?keywords=hirsch+extreme &categories_id=&inc_subcat=1&manufacturers_id=& pfr om=&pto=&dfrom=&dto=&x=0&y=0
WatchObsession have been chosen by HIRSCH to be an
AUTHORISED HIRSCH INTERNET WEBSHOP,
this ensures that the quality & service Hirsch offers,
is followed through to you, the customer, don't accept anything less.
Make sure you are ordering the correct size strap !!
The easiest way to measure your watch band is to simply check the inside of your old band. Most straps have the sizes imprinted on the inside of the band. Secondly, you can measure the band itself, remove watch strap and measure the width of the top of the watch band, this is the side of the band that attaches to the case. Lastly, you can measure the distance between the watch case itself (lug to lug). Most watch bands are measured in millimeter sizes. Use a ruler or a metric (mm) units to measures the band or the distance between the case or lugs of the watch. Measure the width between the extended parts of the case in mm, this is the size that needs to be ordered.
* Please ensure you have purchased the correct size *
*** Watch pictured NOT included ***
** Photographs are the property of WatchObsession and are not to be reproduced without prior permission under Copyright Protection. **
:-! Thanks for looking !!!
