1 - 9 of 9 Posts
Hi guys
I have a king seiko quartz 0852 8000 that is lagging about 2mins/day. May I know which screw should i turn to make it go faster?
Picture of movement attached below:
Thanks
At two minutes per day, I am not sure the trimmer condenser is going to be of much use.
Unless the battery is on its way out or someone in the past went crazy fiddling with the trimmer condenser, then yes, I would suspect that the IC is faulty.
Still, if you want to give it a go, I think the trimmer condenser is here :
Discussion Starter · #8 ·
I gave the screw a few 1 deg turns clockwise but the time is still lagging. Then I saw that the movement of the second hand was irregular. Sometimes it ticks at 1 sec, sometimes at about 1.5-2 sec. Does this confirm that the IC is faulty?
I would think so.
1 - 9 of 9 Posts
