1 - 3 of 3 Posts
I recently purchased a used 5610. I know there are several tests involving pressing a few buttons at once. Is there a list of these tests and how to interpret them? If not, can one of you G shock Masters generate such a list?
Thanks in advance!
Sent from my SM-G930V using Tapatalk
Here's what works on many of my solar/atomic Gs. It will probably work the same on yours.
G-Shock Test Modes
Note: Tested on G-Shock GW-2310-1 and GW-M850-1
Press and hold the following simultaneously:
Top Left, Top Right & Bottom Left - Tilt sensor test (shows TLT)
Time display area shows blank when not tilted, 8888 when tilted
Press Bottom Right to escape
Top Left, Top Right & Bottom Right- Solar cell test (shows SLR)
Time display area shows blank when exposed to light, 8888 when there is insufficient light
Bottom Left, Bottom Right & Top Left - Display test (and module version)
Press Bottom Right to scroll through various screens and escape
Bottom Left, Bottom Right & Top Right - Time sync hardware test
Shows radio-controlled transmitter countries/frequencies, etc.
Press Bottom Right to scroll through various screens (transmitters, etc)
Press Top Right to initiate a sync with the selected transmitter (optional)
Press Bottom Left to escape
1 - 3 of 3 Posts
