Hi all,
i just bought my first chronograph wathc, it's a Jacques Lemans London Moonphase.
But i have problems setting the watch. :(
I cannot pull the crown! Is there a specific way to do it ?:roll: It is not a unscrew crown, cause when i rotate it the second hand and minute hand rotates also.
I tried to pull it harder but it doesn't work, i'm afraid i will break it.
Any suggestions ? :roll:
Discussion Starter #2
also my small second hand doesn't work! :(
does it supposed to work always or i have to make it work ?
sorry im really new to this :(
Well, it is chrono, so I suppose pressing button on top will start the chrono second hand (main second hand) to start move.
Sounds like the crown is already in pulled state if the hour/minute hands are moving when you turn crown.
My suggestion would be can you try to screw IN the crown? Maybe at least push in the crown? Then, one of the sub second hands (small second hand) should start to move.
Damn i'm such a newbie :)) I pushed the crown and now it works...
It was pulled out to the max and i just thought it was normal.
Thanks for your help :x
I'm glad you figured it out ;-) That is a nifty little complication watch you have there. Congrats on your new moonphase chronograph!
