Folks,
Fellow HEQ forumner David Johnson (dwjquest) has been compiling serial numbers for Omega 2400 Marine Chronometers. I've attached his results to date. If you have a 2400, or have a picture of a 2400, that has a serial number other than those listed, we would appreciate it if you could post a picture of it with the serial number clearly showing or stated. If possible, it would also be nice to know if it has a 1511 or 1516 movement, and, if you have the Besancon certificate, the certificate number and date. (These are the first two entries on the certificate.) If you would prefer to remain anonymous, you may e-mail the pics and information to me, and I will see that David gets it.
The 2400 is a remarkable instrument that is unique in the annals of horology. Introduced in 1974, it was the first (and remains one of only three) wristwatch to use a megahertz range AT cut quartz crystal. This extremely demanding and cutting edge technology made it by far the most accurate wristwatch ever made to that time. Even today, few watches can outperform it. By compiling serial number information, we can make inferences about the production of this remarkable piece. For instance, from what David has already collected, we can infer that there were at least two distinct batches made. (Probably separated by the 1511 and 1516 versions.)
We appreciate your help in piecing together an intriguing bit of horo-history! :-!
