1 - 20 of 59 Posts
As title.
Some dayes ago I want to an Omega boutique to try both Omega PO 42mm and 45mm.
Before this try I was quite sure that I would have bought the 42mm, I have a 6.7inch wrist.
I find the 42mm really small, it seems to have the size of a dressy watch with a diver case.
The 45mm is a monster on my wrist.
I was sure that I would have bought a Planet Ocean but now I'm not so sure.
You need a 43.75mm PO. Haha.
seriously though, with an under 7" wrist, the 42mm should feel/fit right for most. My wrist is 7.5" and after having owned the 45.5 black/white twice, I now have a 42mm black white, and find it to be much more more wearable. I loved the look of the 45.5 on my wrist, but I grew tired of the size and mass.
I'm talking 2500 PO's by the way. Maybe the 2500 45.5 would feel like an in between for you vs the 8500's.
A 42mm PO does not wear like a dress watch. I have had the 45mm PO and the 42mm in the 8500 iteration. The 42mm really fits a sub 7.5" perfectly. It wears very comfortably and I don't think anybody has ever mentioned the word small when they look at this watch. I have the exact same size wrist as you and the 42mm is so very perfect size wise. It seems a bit smaller because of the bezel, but measure lug to lug and with crown and it is actually a rather large watch. I guess you think a Sub is smaller than a dress watch? I bet you would be very happy with 42mm.....or you could go 45mm on rubber, but it is still a very big watch and the lug to lug will cover your entire wrist.
Discussion Starter · #12 · (Edited)
Here is your solution! Ceramic bezel and dial, perfect size it height combination. I have a 7.75 inch wrist. The 8500 is a little bit thick for my taste (no offense to any owners).
I like the SMP but this could be my fourth choice in Omega house,
my ranking is:
1) PO
2) MoonWatch
2) Acqua Terra
3) SMP
fourth position may seems low but I low omega watches so I like SMP a lot even if in fourth position :D
The 42 only seems small when put aside a 45.5 PO.
My wrist is the same as yours and I have the 42. Started with the 45.5 but swapped it after a year and half.
The 42 is by no means a small watch on my wrist and is the biggest I'll ever go with a watch.
I have a a few pictues in this thread comparing the 42 and 45.5.
https://www.watchuseek.com/f20/my-new-po-2500-my-old-po-pics-806189.html
Like Franzy, I have a 7.75" wrist. I sold my 42mm PO 8500 because it was just too big, especially the 16.3mm height. Now I rarely wear my Sub-C because it is not as comfortable to wear as the AT, the Daytona or the JLC.
When I bought my 2201.50 in early 2011, I too compared it to the 45.5 model. I actually bought the XL, but after three days of staring at its steadily expanding size, I returned it for the 42. You should get what you think you'd most like, but I'm afraid a 45.5mm watch on your 6.7" wrist will end up scaring horses and small children. ;-)
I first owned the 42mm PO and found it to be a perfect size for my 7.5-7.75" wrist when worn on the bracelet. However, I much prefer the look of the PO on rubber, and found it to wear particularly small for a dive watch when on rubber, so I sold it and got a 45.5mm instead.
I then realised that I wanted a watch I could wear on rubber AND on a steel bracelet, and the 45.5mm unfortunately didn't fit the bill either, as it was just slightly too large for my tastes on it's bracelet.
Will hopefully pick up a PO GMT in the next couple of years if they decide to make one with silver numerals. That looks like the ideal size!
Sent from my HTC One using Tapatalk 2
Seriously, I would rethink the 42mm. I do agree that the appearance on the wrist is small for a 42mm diver watch, of considerable thickness. I have a 7.5in wrist, tried it on and found I like the 45.5mm size a lot better. That is unusual for me, as I usually gravitate to smaller watches. My AT8500 midsize 38.5mm is perfect for me, yet strangely the 42mm PO did look small.
I can't imagine the 42mm seeming too small for your wrist. It seems like it would be the ideal size. Amazing how much difference 3mm makes!
Good luck in your decision. Anyway, I would really try the 42mm again. Maybe the small appearance is due in part to the thickness of the watch. It is quite hefty, and you would normally expect a watch of that thickness to be more the size of the larger one.
Cheers,
Carl
...... Maybe the small appearance is due in part to the thickness of the watch. It is quite hefty, and you would normally expect a watch of that thickness to be more the size of the larger one.
Cheers,
Carl
I agree Carl. The 8500 PO's are quite thick, and perhaps the 42 just seems smaller than it is because of this. I think the 42mm 2500 is just right though...perhaps a better fit for the OP.
My wrist is about seven inches, maybe slightly under right now and I wear the 42mm with pride. I can't imagine anyone ever telling me that my watch looks too small on me. You are only thinking it is small because you are comparing it to something else. Look in a full length mirror and see how much of your wrist it actually covers. I can't imagine wearing anything bigger and heavier than this.
Untitled by Vertec, on Flickr
1 - 20 of 59 Posts
