Orient Instruction Manuals and Caliber Technical/Repair Manuals...
50667 Views 10 Replies 9 Participants Last post by  rustinbox
Attached please find pdf's of the full caliber breakdowns for the following orient calibers:
- 46D41
- 46U40
- 46X51
If any of you find any others, please add them to this thread.
1 - 11 of 11 Posts
Re: Orient Instruction Manuals and Caliber Breakdowns...
The following are PDF's of Orient's instruction manuals, copied directly from Orient's Instruction Manuals page here:
http://www.orient-watch.com/support/manuals.php
To learn how to use your watch, download the PDF file for your model as described below. Please look at the markings on the back of your watch to identify the model code.
Step 1. Check the model code on the back of your watch.
Step 2. Find the first two characters of your model code.
Step 3. Click on it and download the PDF manual.
For mechanical models with any of the models codes ET, ES, EV, FE, EX, FD, FC, EY, EZ, FA, FH, FM, FT, FN or FP, use this instruction manual:
ET, ES, EV, FE, EX, FD, FC, EY, EZ, FA, FH, FM, FT, FN & FP.pdf
For mechanical models with any of the models codes EM, EU, ER, NR, NQ, PF, PM, use this instruction manual:
EM, EU, ER, NR, NQ, PF, PM.pdf
For Quartz models, use whichever of the following instruction manuals corresponds to your model code:
GX.pdf
RL & RG.pdf
TD.pdf
TT.pdf
UT.pdf
UU & UV.pdf
VD.pdf
VF.pdf
VZ.pdf
Reactions: 1
This thread is quite old, but hey I'm new here. Big Thanks!
Hi, Thanks just found the manual for my new,to me, Orient CVZ02.
Hi Does anyone have anything on an Orient Cal G 529608-40 CA quartz?
I can't seem to find anything on it.
It has 52950 on the movement.
Could do with a parts diagram to see if anything is missing.
Even an Orient battery catalogue would be useful.
Thanks in advance.
Anyone have a source for a mainspring for Orient 46941?
Thanks,
Brian
Thanks,
Brian
Did you try ScotchWatchParts? Blake has a good selection of parts.
You can obtain the mainspring through the JDM website Online Japan
Reactions: 1
Can you please provide a link? Not sure whether you meant this site? I could not find mainspring there.
Many Orient calibers have very close Seiko caliber. If we can identify such similar calibers, it may solve up to 25% of all questions re technical guides.
For instance, many old Orient Stars, Mars Orients and Pana Aimant models have caliber close to Seiko Cronos cal. 54 or 56.
1 - 11 of 11 Posts
