1161 - 1180 of 1209 Posts
Looking for a new crystal for my Sputnik!
The one that is in it now has got a small crack.
Diameter 313, high 50
But I can only find acrylic crystals 4mm high!
Who knows where to get the correct size?
Verzonden vanaf mijn iPhone met Tapatalk
Does anybody have a spare titanium nitride comb bezel for Komandirskie?
Or maybe a Copernic crown (chromed) and telescopic glass?
Perhaps a Raketa Perpetual XL second hand (gold plated)?
A flat top Big Zero glass...?
I have some parts for Raketa, Zim and Vostok to trade.
Looking for a "crown wheel click post spring" for Vostok 2416b movement.
As shown here #3:
Also I saw a listing of a "yoke spring" on eBay, the yoke spring does look the same as this.
Can anyone confirm that those are the same?
For whom it may concern,
I've just finished fitting this spring into a 2416 movement and it worked perfectly!
Still waiting for a balance assembly though
I am in need of two rubber/plastic pushers for an Aviator chronograph as pictured. The watch is in good shape and working well. One pusher is broken, and the other one seems to be a bit dodgy right now. I have a picture of the full dial and the pushers required. Thanks.
15717639
15717646
Hello all.
I have had a look through the forum but couldn't find anything specifically related to this
I'm looking for parts for a couple of Molnija based projects I have on the go.
Looking for Panerai or similar style sandwich dials, or any other dials and hands for the movement.
Does anyone know where I can source these?
Ideally I'm not looking for replicas of the pocket watch dials and hands but something a bit different.
Thanks so much!!
GJC
Sent from my KING_KONG_3 using Tapatalk
hello,
i am looking for a kirovskie gold plated crown, and an original glass too. to go on a sputnik. Thanks you !
For the archive, I don't know where else to put this:
Interchangeability of stems between Raketa 2609 and 2609.NA
I just found out that the Ronda No. 1838 stem I got NOS from Ebay (in a pink paper bag labelled 'RAKETA 11 1/2" 2609') does nearly fit into Raketa 2609NA movement.
To make it fit and work you'll have to reduce the diameter of the middle section (I) from 1.45mm to 1.35, and remove the "nose" on the longer cylindrical section (II) down to the same 1.35mm.
I used a cordless drill and 400-grit sandpaper (first dry and eventually, wet), a couple of minutes, and calipers.
The lower stem is unaltered, for comparison.
Material property Font Magenta Handwriting Cosmetics
Post deleted.
