1 - 6 of 6 Posts
Dear Friend,
I tried to measure the altitude from an airplane during the takeoff. The reading reach up to 2995 - 3024 m after that the reading not moving beyond this point (flight was cruising at an height of 32000 ft ~ 9753m.
Note: The base altitude set as 19m (dubai airport). Pressure was reading up to 756.
I have tried this 2-3 times, same story. is there any issue with watch?
Is there any mistake on preliminary setup?
is there any manual which describes the initial setup and how to measure the altitude.
Thanks in advance
Dear Friend,
Thanks in advance
Unless your watch is outside the cabin, it's going to read the "altitude" inside the pressurized cabin, which should be no more than about 2500 m.
GaryK30, Thank you for the info.
Tip: climb to 3001 meters! :-d:-d:-d
1 - 6 of 6 Posts
