I have incoming a vintage Citizen 0510-K16008 "Speedmaster" model, and as part of the initial upkeep I like to have done for new-to-me vintages, I wanted to replace the gaskets to maintain as much water protection as possible. (While I don't plan to shower or swim with it on, stranger things have happened than that I've forgotten to take a watch off as I jump in the shower!)
I contacted Citizen to check their records for gasket specs/part numbers and was told that, while they have info for caseback and crystal gaskets, they have nothing for the crown and pusher gaskets. A search of WUS threads hasn't yielded anything, either.
Has anyone in WUS land replaced their "Citi-Speedy" gaskets, and if so, where did you spec them or source them from?
Any help or suggestions would be appreciated.
Cheers.
- Chris
My jewler has a ton of different sizes and when specs aren't available he just tries on a bunch till he gets a good fit. Then he writes it down for his records. He states it's more common to not find a published spec than not on older entry level watches, or as he likes to say "a challege".
Sent from my SM-T560NU using Tapatalk
It'll take the watch out of service for a while but I would get the old seal/gasket measure and order some in that size range and start trying them on. Good luck.
Thanks. Good call - I guess that's just one more reason why we have multiple watches! Hopefully my watchmaker will see it as a challenge and not just a PITA! If my watchmaker tells me the gasket specs I will post them in case anyone wants to change theirs.
Cheers.
