Hi folks,
I've got a ladies Edox quartz watch on the workbench currently with a non-running movement. I've resorted to repairing ladies watches now so I don't have the temptation to keep them after repairing it.
The movement itself, the gears and date complication, all seem to work fine. The crown engagement feels solid, date and time setting works very well. I'm fairly confident in saying that there's nothing wrong with the gears, but that the fault lies somewhere in the circuit board. Arguably a cheaper one, "Thailand Movement" instead of the ETA board, but this is what the watch came with when I received it so I'm fairly certain that it belongs to this watch (unless someone knows it's not and should have the ETA branded circuitry).
Now replacing the entire movement seems a bit wasteful and unnecessarily costly - a new ETA 956.112 movement costs around $50 (incl. shipping), whereas the circuit board sold separately sells for between $5 and $15 (even for an ETA branded one). But in order to avoid wasting money and time, I have a question to which I think I should know the answer, but as a novice is probably best to ask the more experienced folk here on the forum.
Can I just replace the circuit board in its entirety? This would save a lot of hassle, too. I wouldn't have to remove the movement from the case, remove the hands or dial, all extra points of potential damage or breakage. Cheaper too.
I have already removed the movement on this one, relatively easy, only three screws and loose she comes.
I would love to hear your thoughts on replacing just the circuit board instead of the entire movement!
Attached below are some pictures of the watch with exposed movement and circuit board.
Cheers,
TJ
Cheers,
TJ
