1 - 20 of 22 Posts
hello everybody,
I just got a really nice Hamilton Jazzmaster slim, but I have to ask this: I noticed if I swing it to spin the rotor it makes quite some noise presumably against the backcase. Does anyone else have this watch or have this issue? I'm assuming this is not that normal at all as I have cheaper auto's where I can't almost here their rotor spin. Opinions please.
Some autos make noise, some don't. If it works, don't fix it.
cottontop
Reactions: T-hunter
I have a Hamilton Khaki Action Chrono with a 7753 and it makes a little buzz when the rotor gets spinning. I've heard that is normal.
Some auto make noise, some don't. If it works, don't fix it.
cottontop
Thank you for your input. That is my way of thinking as well.
I have been searching WUS and the web about this noise and this movement in particular and it seems to be normal. Thank you.
Yeah, it's normal. Most of my watches make a noise when the rotor spins.
While it's difficult to say definitively whether there is a problem or now, it's highly unlikely the rotor is scratching against the bridges or the caseback since that amount of friction should affect winding enough for the watch not to function properly.
If you're THAT concerned, get it checked out.
My Seiko 7002 does this as well; but it's normal. :)
Moderator Public Forum
hello everybody,
Hi. If the rotor is actually scraping against the case back that would indicate a worn rotor bearing or a movement fitted to the wrong case. Because this is a new watch I think you are just hearing the normal sounds it makes.
Discussion Starter #11
Unfortunately I'm not sure what it is. If I turn it upside down, and spin the rotor it won't make any noise.
cottontop
+1.
The ETA 289X makes a sound--like a zipp or a swirl. The 775X winds in one direction, thus more of a rattle/whirl (known as rotor wobble, it's the rotor moving freely in the non-winding direction, and just seems to come "alive" on your wrist!). If it's keeping good time and you're not hearing any scraping noises, then there's probably no need to worry. Wear it in good health.
Does the watch reach it's power reserve of about 38 hours without handwinding? Also was your watch new when you bought it?
Discussion Starter #14
I don't know if it reaches it's full power. I took it out of the box yesterday. :) Also the watch is brand new. Nonetheless I went back to the shop and explained the situation. They promptly traded mine for a new one that had just arrived. So question solved. The previous watch did make a lot of noise compared to new one. Thanks everyone for your input.
Your experience shows the value of buying from a dealer. Glad it worked out. Be sure to post some pictures too!
I'm glad to hear everything worked out for you, too, and sounds like you have a really good dealer there. Wonderful to hear.
Cheers.
p.s. yes, please do post some pics, would love to see it, too. :)
Discussion Starter #17 (Edited)
This a crappy pic taken a few hours ago (already posted at WRUW). I'll take more later. Thank you.
Edit: two more pics:
also depends on whether the noise is like, "akka akka akka akka," or "weebeeweebeeweebee." If it's going "shoop fwing, shoop fwing," then that's something else entirely.
Discussion Starter #20
Love the black dial against those dauphine hands and markers. Are there stripes on the dial too?
Nope the dial is interely black, no stripes. :)
1 - 20 of 22 Posts
