Beauty !![]()
What insert is that and are they easy to change?
Beauty !![]()
It's an eBay one I found. Because of the way the gmt bezel is attached with a retaining wire removing the entire bezel is next to impossible without specialized tools...Beauty !
yeeeeees ye ye ye Oh Yes!nooooooo no no no onoon
I'm bumping an old thread because I loved the mod that nikbrown and ten13 did and purchased this all black bezel. It would not snap in as described. It was slightly too small and doesn't have the same geometry as the original. I popped the whole bezel off, removed the OEM insert just fine. Also it went back together with no problem (yes the OEM insert snaps). But the aftermarket didn't fit.It's an eBay one I found. Because of the way the gmt bezel is attached with a retaining wire removing the entire bezel is next to impossible without specialized tools...
I popped the old bezel insert out with an exacto blade (but not without damaging it, i only recommend you do it that way if your existing bezel insert is already beat up)
https://www.ebay.com/itm/311588674473
Yea we had to use glue... it doesn’t snap in like the OEM... I use rubber contact cement... that way it’s always reversible.I'm bumping an old thread because I loved the mod that nikbrown and ten13 did and purchased this all black bezel. It would not snap in as described. It was slightly too small and doesn't have the same geometry as the original. I popped the whole bezel off, removed the OEM insert just fine. Also it went back together with no problem (yes the OEM insert snaps). But the aftermarket didn't fit.
I'm not being a buzzkill, just realize you may get an insert that doesn't work like I did. BTW, I decided not to use glue so the OEM is back on. It's actually a pretty big buzzkill for me because I like the all black look much better.
Cheers,
Tony
I'll have to try again with the rubber cement. I really like the all black bezel insert!!!Yea we had to use glue... it doesn’t snap in like the OEM... I use rubber contact cement... that way it’s always reversible.
