1 - 20 of 27 Posts
· Banned
At one point and time, many had hoped to see one of Seiko's greatest innovations in one of their most coveted dive watches. The thought of a Spring Drive movement in a Tuna Can body came to reality in a limited edition model labeled the SBDB008 in 2013. Sadly, this piece was limited to only 300 pieces for the world and was sold out incredibly fast. There were rumors that the SBDB008 was going to be the one and only Spring Drive Tuna, but thankfully those rumors turned out to be false. For 2014, Seiko introduced the SBDB009 an all black version of the LE Spring Drive Tuna.
The dial of the SBDB009 is deeply recessed, with the center of the dial deeper then the outer ring for the indexes and the chapter ring on an impressive deep slope. This allows for a very thick sapphire crystal to help in its 600m water resistance. The crystal has Seiko's proprietary 99% clarity coating for anti-reflective purposes and the large hands and indexes on this piece offer incredible legibility. The minute and second hand reach out far to the seconds/minutes track on the chapter ring adding even more quick glance visibility. All hands and indexes are applied heavily with Seiko's LumiBright luminescent material with the exception of the whole seconds hand. It does make up for it however, by having a luminescent dot for the tail.
The outer case or shroud on this model is DLC (Diamond Like Carbon) coated titanium. This shrouded design was actually inspired by a letter Seiko received in 1968. The letter was from a professional diver who lived in Kure, a coastal city near Hiroshima. This diver worked in depths as deep as 350m and needed a watch that could resist not only the depths, but also the strong shock of being beaten against rocks on the ocean floor. Seiko's team was shocked, and went to work on creating a piece that could survive these harsh conditions. After 7 years, Seiko introduced their first 600m diver watch, the 6159 in 1975. This watch was the first to use a titanium shroud, which added greater shock resistance as well as being light weight and corrosion proof. Most importantly, the watch could not be penetrated by helium and the new accordion style strap that remained tight on the wrist, even when the wet suit shrinks due to the pressure at great depths. This new SBDB009 utilizes the same design elements as found on the model from 1975.
The bezel has some very special features to create a beautiful feel when in operation. This "Triple Safety Rotating Bezel" is achieved by a special lubricating material between the case and bezel, the shrouds design that protects the bezel leaving it only slightly open from the 12:00-3:00 and 6:00-9:00 area that also allows for easy turning, and a special structure that allows the bezel to only rotate counter clockwise, ensuring the bezel will not move clockwise at all. The shroud is made of Seiko's proprietary Bright Titanium with DLC coating, while the inner case does contain some stainless steel. The possibility of achieving a 600m dive watch with no helium release is reached by utilizing a special rubberized material called "L-Shaped Packing Material" in the case structure, giving it complete air and water tightness. The result is a 50.7mm wide by 16.2mm thick Professional Specifications piece, that sits great on the wrist due to its virtually non-existent lugs making the lug to lug length only 49.6mm. A piece of this size only weighing 126g certainly adds to its comfort.
I mentioned the design of the strap and its use on the 1975 diver the 6159. This is still adopted in the Tuna's design today. Many may remember last years SBDB008 coming with the same polyurethane strap as most of Seiko's divers. While this was some what of a disappointment, it was still very functional for diving. The SBDB009 however did feature an upgrade on the strap, now utilizing Seiko's Extra-Strength Silicone material providing about four times greater tear resistance, superb flexibility and an ultra smooth and soft feel. The accordion style design is still there, providing the same functionality on the polyurethane with the inside of the strap gripped to hold onto your wrist.
Inside this insanely sealed case lies one of Seiko's most innovative movements, the Spring Drive 5R65 caliber. This unique mechanism uses a mainspring as its sole power source with both hand-winding and self-winding capabilities. The energy from the mainspring not only moves your traditional gear train, but also powers an electronic regulating system that would replace a traditional escapement. The frequency from a quartz crystal (of which Seiko grows in-house), is almost 8,200 times faster then that of a common escapement, making it of course substantially more precise. The frequency from these crystals goes to an integrated circuit (also developed in-house) that translates that frequency to an electromagnet. The electromagnet basically regulates a wheel that turns freely in one only direction (unlike a balance wheel that rocks back and forth on a hairspring) telling the wheel to only turn 8 times per second. This makes the mainspring unwind at an unbelievably precise pace and move as fluid as time itself, creating a second hand that glides as opposed to a sweep. This smooth uni-directional motion allows for the smooth gliding second hand, incredible accuracy and a significant reduction in stress on the movement. Seiko's proprietary alloy Spron 510 that is used for the mainspring material also provides a 72 hour power reserve off only one mainspring, which can be monitored on the dial. The display of the power reserve will reflect tightness of the mainspring, with a full power reserve expressed with the hand all the way down showing tightness, and all the way up in the red section meaning it is near fully expanded.
As a great dive watch should, the SBDB009 provides excellent legibility in the dark. LumiBright's glow can last up to 10 times longer then conventional luminous paints, has a stronger glow intensity, is non-radioactive (so safe for people and the environment),the quality of glow can be sustained over a long period of time.
The Seiko Prospex Marine Master Professional 600m Spring Drive Tuna Can SBDB009 retails for $4,200. It can be viewed on the AZ Fine Time site HERE and can be ordered by calling us at 1-800-486-3996.
Thanks for reading!
See our video review below…
SEE MORE PICTURES HERE
· Moderator
Awesome thread Joe!!!!
IMO the SD Tuna is an incredible watch. Thanks for taking the time to put this together:-!
BTW killer photos & video!!!
Cheers
Shannon
Stopped by the Seiko boutique in NYC this weekend specially just to see the SD Tuna. The bezel action and feel was the most impressive I ever seen, on any dive watch at any price range. I am thinking about selling off a few divers to make room for one of these. The 50mm size was also to my surprise, very wearable. Checking out this next to the GS Diver quality seemed to be very close which really adds the value factor to me. Not a dress diver by any means but IMO the ultimate casual piece.
Fantastic watch! Very nice indeed!
Love the way they got the 600m case with screwback.... which for a springdrive, makes me say why not monoblock case? Not like you'd have to change the battery.
DLC finish is tungsten carbide vacuum deposited on the surface. Could be with some titanium or boron in the mix, as every plating house has its own recipe depending on color and texture desired. It is some hard stuff. Sales and marketing call it diamond like coating, diamond like carbide, diamond like _carbon_, etc. , but its tungsten. Sometimes, you'll think you scratched it, but no. What's really happened is the matte texture of the DLC coating has scraped other material it hit... into its pores at the surface, and a good scrubbing removes the "scratch" that wasn't a scratch at all. Amazing finish, and its very anti-corrosive as well.
I'd love to hear how the accurcy is in the spring drive. Theoretically.... there should be no "wear in" of the mechanism to stabilize the regulation, as the springdrive itself is a sort of feedback loop which would compensate.
· Banned
The screwback is for easier servicing, as it needs oiling every 3-4 years.
I agree the DLC finish is amazing. I've banged my watch several times and at least on 3 occasions, hard marble. I've always thought, "DAMN IT" but when I look at it... no scratch! I even had a scratch on the bezel for a good three months until it suddenly disappeared, which leads me to believe it was something I banged it on that got stuck to the surface temporarily.
Accuracy is amazing as in 1 month time, I was running ahead by 2 seconds!
If they make it a mono block case, it will be too big for most people to wear. Spring Drive movment is huge. If you see the SBDB003 [ the previous SD Landmaster,] you'll see what I mean.
I just picked mine up and am really blown away. For its dimensions, it wears MUCH smaller, extremely comfortable. Of course, I am used to big divers, but this is great as it is big and light! Accuracy, over a few days mind you, is perfect. I had wanted a Spring Drive, and this is it. Really pleased!
Unfortunately, I find the shroud pretty easy to scratch, already have one in there... Disappointed in that! Oh well, hopefully when it is beaten up, it is easy to replace. Right Tuna fishermen? RIGHT???? :)
Awesome review... Mine said hi...
How ever I do notice the lume on the bezel has droplets of water in it when I shine a torch on it... Anyone has the Same issue?
Reactions: Spring-Diver
The finish is one thing, but the extremely fine brushing on the shroud will easily scratch.
I personally think the finish on the shroud is about as nice as anything I've ever seen on a watch. It's incredible. The problem for me is that a Tuna is a tool watch and I knew both times that I owned this and the 008 that I was going to destroy the value. I absolutely love the watches, but I don't want to see that beautiful finish scratched up. OCD as hell, I know.
Reactions: CitizenM
Unfortunately, I find the shroud pretty easy to scratch, already have one in there... Disappointed in that! Oh well, hopefully when it is beaten up, it is easy to replace. Right Tuna finshermen? RIGHT???? :)
I cringe at the thought of replacement cost for that shroud. It's going to be very expensive.
1 - 20 of 27 Posts
