Sold
WTT: Sinn UX S on Mint Rubber/Buckle for Sinn U1
This UX model is a little thinner and lighter on the wrist. Much more comfortable than the U1.
Trade value 2K.
Few, if any marks. Near mint condition.
Comes with boxes, warranty card from Feb 2020, booklet, Sinn tool, rubber and buckle are mint. Box has some wear on it.
Can trade (down/even/up) for Sinn (only): and looking for a (preferably) newer U1 (original), U1-T, U1 SDR, or U1-T SDR.
Quartz Movement
ETA 955.652
High-precision quartz movement
Temperature compensated
7 bearing jewels
Seconds stop function
Shock resistant as per DIN ISO 1413
Anti-magnetic as per DIN 8309
Case
Case made of German submarine steel, black
Sapphire crystal glass in front, anti-reflective on both sides
Case back screw-fastened
Meet the technical requirements for waterproofness, as set out in standard DIN 8310
Pressure-resistance of the movement up to 5,000 m diving depth (= 500 bar) and of the case up to 12,000 m diving depth (1,200 bar), certified by DNV GL
According to the technical demands for the diving norm DIN 8306
Tested based on European diving equipment standards EN 250 / EN14143 and certified by DNV GL
Low pressure resistant
Functions
Hours, minutes, seconds
Date display
Diver's bezel with minute ratcheting and luminous key mark
SINN Technologies
Black Hard Coating on a TEGIMENT Technology basis
HYDRO Technology for perfect readability even under water and freedom from reflection at any angle and completely free from fogging
Captive bezel
Temperature resistance technology, therefore functionally reliable at temperatures from minus 20°C up to 60°C
Crown with D3-System
Dimensions and Weight
Case diameter: 44 mm
Band lug width: 22 mm
Case thickness: 13.3 mm
Weight without strap: 105 gramme
Dial and Hands
Matte black dial
Indices coated with luminescent colour
Hour, minute and second hand coated with luminescent colour
Mission timer design for optimal readability
Trade value 2K.
Quartz Movement
ETA 955.652
7 bearing jewels
Case
Functions
Date display
SINN Technologies
Captive bezel
Dial and Hands
Matte black dial
