I got some off of an old strap thrown out at walmart .I just asked for a discarded watch I spied.Worse comes to worse you can get a 20 mm Speiel strap with them.OR, did you mean Speed racers other Brother,( Stepbrother actually) the one who is a Jeweler?
G
:):)I have finally tracked down two sources. One was out of 18mm , but the other had them in stock and they are on the way. Thanks, speedracers half brother, speedbar is alive and well and will soon be living in South Carolina
G
A very small rectangular hole is cut in the back of the strap where the spring bar goes thru. A small knob protrudes thru this hole from the bar. Pushing the bar toward the center retracts the bar from the lug, allowing the strap to be detached without scratching the lug. Hope this explains how operates. If not, please feel free to ask for further explication. Regards
