I see no real pattern for which batteries die and which survive.
I had to exchange the battery in a GW-225 after 10 years (that i only wear once every few weeks).
Another GW-200 of the same age and use is still strong
And several GW-M5600s in much heavier rotation, at the same age and with smaller batteries are still doing fine.
The oldest GW-500 i own needed a new battery after 15 years or so and so is the oldest solar G in my pile.
This is a thread I started last year related this issue:
https://www.watchuseek.com/f17/gw-m5610-light-problem-5023707.html
The watch is still showing a high charge and exhibiting the same occasional problem.
It occurred to me that maybe the way a watch is used could have an impact on solar battery life.
The problem with mine occurred after I had been using it every day for four years straight including several times daily use of the EL, hourly chime etc, continually charging and draining. I guess most G's here are part of a collection and unlikely to see the same pattern of use, arguably equivalent to 8-10 years wear if worn 2-3 times per week and spending the rest of the time asleep in PS or perhaps sitting on a sunny window sill. I wonder if battery problems are seen more in watches in constant use?
