1 - 13 of 13 Posts
Hi Guy's,
I have a vintage Casio F-8 that i purchased way back in 1979!
It needs a new battery, do any of you know which battery
fits this model???
On the back of the watch it say's: JAPAN W 452917 & 58F-8
Do you know what these numbers indicate?
Cheers to those who can help. :-!
Open the watch and see what battery is inside. Be careful not to turn the watch while it is open (some quartz watches have loose parts inside).
Yeah open the caseback, I'd love to see what a 70's battery look like :D
There is no battery inside, that's why i'm asking what battery it requires!!! :-s
At least try to post a picture of the watch with case back removed, depending on the size of the battery holder, someone might be able to help you.
I've seen a couple of vintage Casio watches with the 2020 battery.
Discussion Starter · #7 ·
Ok, so i've measured the battery aperture and it looks as though
the original battery was 23mm x 2 or 2.5mm.
I know for sure it was a lithium battery and that it was 3v.
Does this shed any more light on the subject. :-s
Thanks for the help so far guy's. :-!
So you could try either a CR-2325 or CR-2320, they are both 3V batteries.
yeah the 2 first digits are diameter on lithium batteries, the 2nd two are depth
So a CR23(diameter)20(depth - obviously stick a decimal point in the last pair) or 2325 should be fine
I also think the CR-2320 would fit better if there is a spring underneath.
Discussion Starter · #12 ·
....I've learnt something new today, thanks! :-!
Discussion Starter · #13 ·
Ivt, Watchma & Brigalow, thanks for your input guy's.
I really appreciate your help. :-!
I remember having this watch for christmas in 1979.
It was my first LCD watch, just wish the strap had not perished years ago. :roll:
1 - 13 of 13 Posts
