1 - 20 of 66 Posts
If you want to give a watch a quick bath under running tap water, or take it into the shower with you (but not swimming), what would be the safe minimum water resistance?
Obviously I think anything with a screw-down crown and at least 100m WR is not gonna have ANY issues with this.
But what about when we are talking no screw-down and WR of 50m or 20/30m like a dress watch?
Most manufacturers have a guide for what they determine is safe for the specified WR, it does seem to vary by manufacturer slightly
Here is Seiko's for example
And Omega's
Here is a general guide, from what probably should have been your first stop ;-)
Water Resistant mark - Wikipedia, the free encyclopedia
Thanks. Probably kind of stupid, but I have a hard time gauging how much water/ pressure I'm subjecting my watch to if I'm washing it off with water/soap under running tap water. Doesn't feel quite like a shower because I am concentrating the water at the watch itself, but doesn't feel quite like a swim since the watch is never completely submerged in water at any point either.
There is a difference between swimming with a watch and showering with it.
Hot water and soup can eventually turn rubber seals into butter.
Sent from my iPad using Tapatalk HD
The Benrus field watches issues to GIs in WW2 weren't particularly water-resistant, but they handled charging off a landing craft, though rough surf and explosions, just fine. I think almost any modern watch, with any degree of water resistance will do equally fine in a sink.
I wonder what they use to seal pipes in a soap factory?
Oh, wait, it the same stuff they use to seal your watch.
Internet myth:
Soap and hot water will " turn rubber seals into butter".
Truth:
Modern elastomerics are very good at surviving simple soaps and detergents. The cause of rubber turning to tar-like goo is generally poor curing and age.
Why do people falsely attribute showering with all sorts of water resistance. I figure that most people get their watch wet the most often while showering, and it is there under that warm spray of water that they first notice the watch is taking on water, so it is assumed that the watch was fine, until something in the shower broke it...
I had a 1 or 2 week old Movado that got wet in the rain and it fogged up...If it does not
have a screw down crown and rated as a diver, I keep it dry!
Never seen soup ruining rubber seals....I don't believe soap will either.
I've used soap to lubricate rubber seals, per manufacturers suggestion.
Hot water is a bad idea, it will increase the internal pressure in the watch. The seals are designed to keep outside pressure out, rather than internal pressure in. This will probably do bad things to them.
However, soap or detergent is harmless and cold water is also fine.
Hot water will heat up the watch, leading to increased internal pressure. But the difference in pressure, from 20 degrees Celsius to 100 degrees Celsius, will only result in a 27% increase in internal pressure. And that's only when the temperature inside the watch reaches boiling point.
I don't have intimate knowledge about how the seals work, but I wouldn't think a watch designed to keep 20 atm out would fail so easily from a small difference in the internal pressure.
Of course, I could be completely mistaken, in which case I would love to know the details.
To my great sorrow I have experience in ruining dive watch by hot water + unscrewed gas valve.
The HEV is an example of marketing gone amuck, as so many watch enthusiasts seem to think that it's a feature that's essential to a high water resistance watch, when in reality it's utterly irrelevant except for professional saturation diving. While some of the automatic HEVs are at least relatively unobtrusive, a manual HEV is just an additional opportunity for user error and an additional potential point of failure for water resistance.
There is a nice Hodinkee article on exactly this issue,
Opinion: Too Much Hot Air About Helium Release Valves
Butler J80, Omega Speedmaster, Scurfa MS17, Marathon Navigator
I love it when you rescue a thread brother! (and thanking you for it is a fine way to hit 500 posts!)
Internet myth:
Truth:
Reactions: ljb187
Call me neurotic (many do) but I only shower in at least 10 bar watch and swim in a minimum of a 20 bar watch. Anything less I keep well away from water.
A differential pressure is a differential pressure. Doesn't matter which side is the high pressure side, at least the way watch seals are designed and made.
You know they sometimes test watch water resistance by vacuum....
I was leaving a ball once and it started suddenly raining very hard. I did not have an umbrella, but and quickly walked through the rain to my apartment building which was a few blocks away. The 50m watch I was wearing that night later started showing condensation under the sapphire when I was outdoors. Luckily, I was able to get it fixed for free under warranty. The only watch that I purposely will take near water anymore is my 300m diver.
Agree.
Buy any affordable dive watch and forget about problem with water |>
NEUROTIC !!!! ;)
I've washed nearly 50 watches of all ages, makes, and water resistance under tap water with no issues whatsoever. Just make sure all crowns are down and you should be good.
1 - 20 of 66 Posts
