Assuming a good quality watch that is worn daily and has been properly maintained with service every 5 years: What would one expect in terms of part replacement due to wear at 5, 10, 15, 20 etc years?
I read that after 20 years, no matter how well maintained, a watch that is worn every day will need many parts replaced. Is this true? Which parts would likely be worn enough to need replacement?
I feel that a higher quality watch should last for years when cleaned and lubricated. The higher the tolerance the longer they last and better the time keeping. You will find some pocket watch movements marked as safety pinion. This was a change because when the main spring broke the back lash could take out gears. Not including rust or dropping I see more damage done during service where the watch maker crushed a pivot or did other damage during reassembly.
