1 - 7 of 7 Posts
Hoping for some help on this Zenith.
I had the case opened to regulate the watch and compared the movement to Dr. Ranfts webpage.
The movement was allegedly a cal 126-6; however it doesn't appear to be one.
I haven't seen photos of this watch either.
Any help in identifying the movement is appreciated.
Zenith Forum Co-moderator
Huntershooter, please take a closer look on the digits under the balance wheel. Thats the caliber in question.
Looks like a Cal. 126-6 to me. The Cal. 40 is nearly identical to the Cal. 126 but has different keyless works. Compare:
bidfun-db Zenith_40_0: Zenith 40
...with:
bidfun-db Zenith_126_2: Zenith 126-6
The Cal. 126-6 differs from the Cal. 126 insofar that it has shock proofing. The Cal. 126-5 has an indirect central second hand and, if you hadn't guessed it yet, there is also a Cal. 126-5-6 with both features. The double arm on the balance regulator is indeed more characteristic of the Cal. 40 and I wouldn't exclude the possibility that a part not intended for the Cal. 126 had been used. However, that is not the only example of the Cal. 126 I have seen with a double arm.
Your watch is from around 1950 or slightly after (movement serial number 4.2 million).
Hartmut Richter
Hi huntershooter,
simply read under the balance. I can make out at least "-6" from "126-6" in
the photo, and the rest should be readable with average eyes instead of a
long-sighted camera.
Regards, Roland Ranfft
1 - 7 of 7 Posts
