I received my GW-9500-1JF yesterday:
These are my first impressions:
- The strap is very stiff yet the watch is very comfortable
- Initially, I thought there was another piece of plastic protecting the glass and I tried to remove it
- There wasn't
- Yes, the display is dim. Low contrast
- Why CASIO didn't use a lighter background (instead of black on gray)? That would have solved the problem
- Yet, because the digits are, by far, the largest on any of my G-Shocks, time is perfectly readable, which is, for me, the bottom line
- After setting-up and charging the watch from M to H, It synched at 1:05 a.m., at the second attempt
- CASIO removed the charge level bars and left the letters L, M, H, which are tiny, only
- So now, is harder for me to check the battery level at a glance
- I know, I'm nitpicking here but I don't like it when changes are made in the wrong direction
- Most of my MB6 watches synch their time at 12:03 a.m., at the first attempt. So, tonight this one may do the same
- Would I recommend the watch?
- Yes, but definitely, only the positive display one. Unless your main consideration is color / design (which is perfectly Ok, of course)
