So I understand watches have wear and tear and scratches are just battle scars for watches so i've learned to love it however I can not stand scratches on the crystal. I tend not to baby my watches and wear them with enthusiasm however I still managed to scatch the crystal on my orient bambino after two years and my speedy after 18 months respectively. These are the only two watches in my collection with marked crystals so it would be great if i could remove them. I knew speedy was bound to get some scuffs when i bought it but also knew polywatch could get them out but i had never used it before. The mineral glass on the bambino was another challenge. I looked up a few things and saw a product called scratch genie. Ordered them both and got started.
The scratch on the bambino is near the 12 o'clock marker and the scratch on the speedy is near the 11 o'clock marker.
Bambino first...
In progress
End result and new strap
Speedy next - the scratch was much bigger
i re-did the masking after this before using the polywatch
End result
Speedy - Polywatch is a miracle sent from the heavens for speedy owners- I used it with a microfibre cloth. 5 mins later. The hesalite was as good as new. Makes me grow even fonder of the hesalite now.
The bambino - This is another story. I started hand polishing and about 30 mins later, i saw no changes so got the drill out and used the buffing piece that came with it and progress was slow. I kept checking after each attempt (took many) but it took me around an hour ( plus 30mins hand polishing before ) and alas the scratch was no more. This required a lot of work but maybe this is because i'm a complete noob at this and it may not be the products fault. Some of you may wonder why i'd spend so much time on a cheap-ish watch and not just replace the crystal if it bothers me so much. In all honesty, it's party because I wanted to try something new but mostly because my girlfriend bought me the watch for a milestone and it has sentimental value so i prefer to fix it up myself.
All in all, I am very pleased with end results and would give 10/10
Bambino first...
In progress
End result
